Manual Locking Hub questions.
How fast can i safely drive with 4H engaged, 40 MPH?
Can I leave the hubs locked and be in 2WD by just turning off the switches for either 4H or 4L inside the cab? Is it safe to do so? And can i switch back and forth inside the cab to 4WD on a snowy day without having to get out and lock the hubs?
Thank you,
-Greg
I do have the warn lockouts. When you are going to engage 4 wheel drive no matter what, make sure both them are locked in, twice actaully. Wouldnt want to be drivin through mud, engage 4wd and you only have one locked in
I was stuck once...like my rear axle under mud, my drivers rear tire made a 4 foot deep hole, twisted so i only had one front tire spinnin at the front.... ANYWAYS, on my drivers front tire, there was a root that was actaully in the perfect position to unlock my hub. When its unlocked it's not a pretty sound. Trust me, you'll notice it. Sounds like you busted a axle shaft or axle u joint. You will not be able to drive in 4x4 with only one locked in. It will only do major damage.
Question...why do you want to drive in 4h at 40 mph? On the way back from hunting, we were going about 40 in low on the icy road...sucked gas though
you can drive with your hubs locked in, but unlock them when you get out of the mud, or whatever you need 4x4 for. If you drive them locked in down the highway, you will notice the friction. Instead of your front end not doing anything, there's gonna be parts moving because the front end is engaged, obiously.
If its a snowy day, like you said, then keeping them locked in wont cause any problems, as long as you arent going 55 mph...I drove about 5 miles with the 4x4 engaged on a snowy night. No problem. I have been told many times it is not good for the 4x4 when your on pavement. Gravel roads are fine though.
I cant remember with the push buttons, but i think you need to be in neutral to engage it? either that or be under a certain mph...
If its possible, i personally would still stop the truck, put it in neutral and engage it with the push button.
Do you know if these lockouts, and the 4x4 works well? I test drove a '92 with a push button and it had some 4x4 problems. Light not going on, not sure if it was fully engaged, hopping, noises etc.
Also, you won't do any damage at all by having one front hub locked. You just won't have 4wd. You can go as fast as you want with the front hubs locked.
One thing to add is that you absolutely cannot engage the 4wd unless you are on a slippery surface. If you lock the hubs and push the 4x4 button on dry pavement, something will break, usually a u-joint.
I don't plan on driving 45 MPH in 4WD, I was just wondering what the limitations are. I just want to know as much as i can about my truck so that i know what i can or can't do
Also, what is the difference between 4H and 4L? I would assume that 4L would be for slow driving through mud or over really rough terrain.-Greg
-Greg
