Compression Test
Old Nov 8, 2013 | 07:59 PM
  #91
oldbird1965's Avatar
oldbird1965
Oh, by the way Travis, in the soundproofing thread I posted a picture of my cracked bellow.
Old Nov 8, 2013 | 09:04 PM
  #92
OldWoodsDiesel's Avatar
OldWoodsDiesel
Originally Posted by oldbird1965
Why couldn't you say that?? haha I keep forgetting to play with the decibels meter now that I have it downloaded.
:-) ok, next time, i'll say it!
yeah, i'm curious to see what readings you'll get! I took another reading at ~70-75 mph tonight - it was just above 90 dB, which is pretty high, I think.
ok, maybe not, says this page: Decibel (Loudness) Comparison Chart
90 is high, but apparently OSHA says 8 hrs/day exposure to 90 dB is OK. its also funny that this level is associated with 'truck traffic' in the upper list - i'd say that's accurate.
Old Dec 18, 2013 | 12:01 PM
  #93
OldWoodsDiesel
Part Check
Thanks Axel 56.
I think I figured it out. They sold me a wrong fitting making it to tall and putting the metal part of the grease whip to high. This is what I need:
M10-1/8F8OHGS PARKER HANNIFIN CORP. PARM10-1/8F8OHGS CONVERSION ADAPTERM10 X 1/8 NPT PARKER - Marshall E. Campbell Co.
Glenn - I'm hoping to get my compression test done this weekend, but I currently have no parts to assemble to setup with :-)
actually I have a high pressure (1000 psi max) gauge that I 'salvaged' from work, so I'm just looking to make up the whip and check-valve/release valve part of the setup.
from your experience (specifically the quote above), it sounds like getting the correct M10 to 1/8" NPT adapter that goes on the end of the grease whip is critical.
do you think this one from McMaster is the proper one or is it too long like the first one you had? McMaster-Carr
(scroll down for the engineering drawing) I'd like to order from them as it'll get to my house by tomorrow, but if it looks like it may be too long, i'll order from the link above and pay for faster shipping.
thanks!
EDIT: Not quite so pressing now, Glenn - i just called a local shop and they have 3 of the PN you posted in stock. if you know for sure that McMaster one'll work, though, i'll take your word for it and order from them. its a bit cheaper and will save me a few miles driving :-)
Old Dec 18, 2013 | 07:20 PM
  #94
oldbird1965
After checking mine, I think that will work fine. I'm guessing its a hair longer but that shouldn't matter. What did in my first attempt was the adapter I had to use made it to high and it was hitting the rocker.
Old Dec 18, 2013 | 08:10 PM
  #95
OldWoodsDiesel
Thanks for the info Glenn. I wound up chickening out though - I just ordered the other stuff from McMaster and will go pick up the adapter from the Parker dealer tomorrow. I thought about it more and figured for $2 bucks and a lunchtime drive, I'd like to not have to find out the McMaster one was too tall.
I will measure the Parker one against the McMaster model and post the findings here for future reference.
Looking forward my my compression test results!
Old Dec 18, 2013 | 08:12 PM
  #96
OldWoodsDiesel
Stupid double post!
Old Dec 19, 2013 | 01:24 PM
  #97
OldWoodsDiesel
just got back from the Parker store and their fitting is identical to the dimensions shown on the McMaster site. oh well.
so for anyone else looking to make the DIY compression tester, my McMaster parts list should have been:
7775K51 Quick-Opening Brass Check Valve, 1/8 NPTF Dryseal Female Connection, Fluoroelastomer Seal
1195K57 Flexible Grease Gun Nozzle, Polyethylene, without Coupler, 18" Length
4936K153 1/8 NPT Female Adapter x M10 x 1.0 Metric Male
46095K21 Diverting 3-Port Brass Ball Valve, Lever Handle, 1/8" NPT Female x Male
that's about $50 total in parts, which is about the cost of the harbor freight kit, I think. oh well :-)
if you have a diesel (or any 500psi) compression gauge, you may just need the M10 adaptor, or the adaptor and grease gun whip at best. I have a standard 1000psi gauge (no internal check valve or pressure release button) i'll be using, so I needed the check valve and 3-way valve to make it work.
Fingers crossed I get the testing done and get good results this weekend!!!
FirstInFright
May 3, 2016 08:29 AM
Uni Moe
Aug 24, 2014 10:58 PM
twisted
1978 - 1996 Big Bronco
Jun 2, 2007 12:28 PM
Dieseldan7.3
Jul 13, 2006 11:15 AM
tractoman
Feb 19, 2006 02:18 PM
