What sensor is this
Old Oct 29, 2013 | 06:51 AM
RKCORPS25's Avatar
RKCORPS25
What sensor is this
Was thinking it might be the ipr but it was not. It is located on the passenger side right above the gpcm. I took it out and it looked like maybe it was for? Any help is great. Also I was wanting to check/ clean my ipr valve but can not see it anywhere. Any ideas
Old Oct 29, 2013 | 06:52 AM
npccpartsman's Avatar
npccpartsman
The sensor in the passenger side valve cover is the ICP sensor. It means you have an 04 and up engine. The IPR valve is on the drivers side under the FICM behind the turbo and is easier to access from underneath the truck. You'll have remove the rear heat shield to access it IIRC.
Old Oct 29, 2013 | 06:55 AM
RKCORPS25's Avatar
RKCORPS25
Awesome thank you is the ipr something worth cleaning or should I take a look post a pic and maybe have you help me out with you thoughts
Old Oct 29, 2013 | 07:00 AM
npccpartsman
I'm not sure I'd take it out if it wasn't giving you problems. If the oil cooler has been replaced and you're having ICP issues then I'd take it out and check it for sure. The fine mesh screen can get covered and/or compromised and is replaceable. If it has a hole and the IPR is still working consider yourself lucky.
Old Oct 29, 2013 | 07:09 AM
RKCORPS25's Avatar
RKCORPS25
I think I might just hold off for now.
Old Oct 29, 2013 | 07:48 AM
captfatboyf250's Avatar
captfatboyf250
if u do need to pull ur ipr valve for what ever reason ie crank nostart u might try cutting a 26mm deep well socket worked real well or a crowsfoot u could find pics under my post
stick with np he will lead you straight
patino1
Mar 1, 2025 07:41 PM
rangerbob406
Jan 19, 2013 08:14 PM
grif95
Jun 23, 2011 11:39 AM
jet5545
Nov 11, 2008 05:25 PM
