7.3 miss when wiper
Oct 26, 2013 | 09:38 PM
7.3 miss when wiper
Has anyone had problems with 1999 or later 7.3 missing or dying when you turn on the wiper switch? Thanks.
Oct 26, 2013 | 09:45 PM
I have read about others having that issue and the CPS was at fault. Has yoir truck had the CPS recall done yet?
Oct 26, 2013 | 09:47 PM
yes , there are a couple of write ups here about that problem . I think , as stated above , the cam sensor is the problem .
Oct 26, 2013 | 09:50 PM
Oct 27, 2013 | 07:44 AM
It did code the cam sensor but I was told that that code comes up on any misfire. But I will replace it because it won't hurt. It's not to expensive. Thanks.
Oct 27, 2013 | 11:13 PM
Replaced CPS. So far so good. Thanks.
Oct 27, 2013 | 11:30 PM
Oct 30, 2013 | 10:46 PM
Used a BWD from O'rielly Auto. Picked it up after dealer was closed. I'm going to get a Motorcraft one for a spare later.
Oct 31, 2013 | 08:36 AM
Quote:
Originally Posted by
Djack04F150XL
Swap that logic. Use the OEM one as the primary and the BWD as the spare. Or better yet, get two OEM and return the BWD.
I used a BWD with no issues for a good length of time, but others report different results.
Jaden McDonnell
Jul 13, 2017 06:55 AM
Jaden McDonnell
Jul 11, 2017 01:14 PM
Jamie Arceneaux
May 6, 2013 12:01 PM
Elwskw
Oct 4, 2012 11:44 AM
Redully
Apr 11, 2012 10:49 PM
