460 starting issue
Old Oct 26, 2013 | 07:08 PM
sudsmcduff's Avatar
sudsmcduff
460 starting issue
i am posting here cuz i am running out of patience. have had 5 shops and over 8 differnt people look into car not starting. i know without it in front of you cant say for sure, but looking for opinions. 71 tbird 460cid. new bat, starter bench tested fine. all new grounds and wiring/cables. starter gear and fly wheel teeth fine. turn key and it clicks. starter engages but wont turn fly. every now and then it will start out of the blue. sometimes a jumper will start it. thanks for looking-
Old Oct 27, 2013 | 05:15 PM
1979dolt's Avatar
1979dolt
bad cable to the starter or the starter driver is on its way out...
Old Oct 27, 2013 | 05:18 PM
JWC 3's Avatar
JWC 3
How bout the fender mount solenoid ? Any one check that ? Sounds likely to me . Just a thought !
Old Oct 27, 2013 | 10:09 PM
sudsmcduff's Avatar
sudsmcduff
sol is connected to the starter. thanks i will look into the starter driver
Old Oct 27, 2013 | 11:29 PM
slashfan7964's Avatar
slashfan7964
Connect the 2 terminals on the solenoid with a screwdriver and see if it fires up. Your effectively bypassing the solenoid, so it should fire up. If it does, the solenoid is bad.
Old Oct 28, 2013 | 05:18 PM
sudsmcduff's Avatar
sudsmcduff
yea it tested fine. looking into the fun job of dismantling the steering column. everything else has been tested. thanks
Old Oct 29, 2013 | 01:23 PM
iggybob44's Avatar
iggybob44
Shouldnt a 71 have the relay/solenoid assy on the fender well? i wasnt aware of an actual starter mounted one, and its kinda disturbing that a shop cant find an electrical issue on a non computerized, non electronic vehicle....I also woulda thought a 71 would have a dash mounted ignition switch, not a column one.......Does it have a Neutral Safety switch? if its a column auto, have you tried starting it in both neutral and park? it shouldnt even click, if its got this switch, but i suppose the switch could be allowing only a little current flow. Damned frustrating, regardless!
Old Oct 29, 2013 | 04:49 PM
sudsmcduff's Avatar
sudsmcduff
yea had to drop the exhaust and steering linkage just to get starter out with the big ol sol attached to it. yea it should have that safty switch. thanks i will test that next.
ernsppw
Jan 4, 2019 09:25 AM
mac01
24
Nov 27, 2009 03:01 AM
Iowa460
31
Jan 15, 2009 09:49 AM
brs127s
Jan 6, 2004 09:46 PM
benzane
Mar 3, 2003 12:09 PM
