Would a bad starter cause shifting issues?
I'm still trying to trace the root of my X's problems and today while at Auto Zone, I had them run a battery/starter/alternator test and the batt and alt passed but the starter failed by drawing 280 amps...
When I first crank up the truck in the cold mornings, it idles perfect and shifts perfect (although a little soft) but after only a few minutes to warm up, I get a "miss" at idle and the trans intermittently shifts hard from 2-3.
The Torque app says I have a bunch of misfires at idle that go away while driving - does that sound like a vacuum leak?
Anyways, I am determined to get the X back in shape and will greatly appreciate any troubleshooting tips or tricks.
No.
Sounds like you will need a new starter soon, but that's not the source of your issue.
Lots of times a bad coil will first cause issues when the engine gets hot. Are you getting a misfire code? Sadly the OBD-I compliant PCMs in these things are nearly braindead when it comes to misfire detection.
Possibly a vacuum leak, but I don't think it's likely that a leak would seal itself when the engine is cold and cause misfires when it warms up.
I'm thinking I have multiple issues but man, there's nothing obvious! I've gone over all the lines, wires, and hoses in this truck looking for issues but nothing... I have had the truck to different mechs at different times and nobody has found anything. I will admit that I'm NOT impressed with any mechanic I've spoken with though.
Maybe I should start throwing money at it? I'm pretty sure I don't have a plug and coil issue as they've all been replaced AND I have new spares that I have used to "check" for issues.
The injectors were all super clean and orings were in good shape. I haven't done a compression test yet but honestly, I think it would be unnecessary. Oh well, I'll keep trying.
82f100460
03-14-2012 02:50 PM
Rose Clifford
02-10-2011 08:40 PM
