IDI wont IDle down
Old Oct 24, 2013 | 03:01 PM
big ole ford's Avatar
big ole ford
IDI wont IDle down
Hopped in my 94 f350 this morning fired right up as usual and since it was pretty cold I let it warm up before i took off and then i noticed it was idling faster than it normally does. It nrmally idles 750-800rpm but today it was more like 1100-1200 in drive so when i stopped for coffee I opened the hood thinking the fast idle solenoid was stuck but it wasnt so I tried adjusting the idle screw again getting no results, so i drove on to work with no additional problem. Now I drive home from work and it has raised to 1400rpm and developed a flat spot in the throttle response AND the transmission has now started to shift wierd. I guess the injector pump is going out again b/c everything else looks normal if so that will be IP number 3 in a year. I hope one of you guys knows something I dont and i will be grateful if you do... Thanks!
By the way its a 7.3 IDI turbo for the record!
Old Oct 24, 2013 | 04:09 PM
Chevy_Eater's Avatar
Chevy_Eater
Throttle cable sticking?
Old Oct 24, 2013 | 04:45 PM
big ole ford
Duh, I didnt think of that to start with but have tried that now too and still 1400 and rising I sure wish it had been that though, throttle cables are cheap. thanks for the idea
Old Oct 25, 2013 | 05:06 PM
big ole ford
Fast idle solenoid died, that was my problem. I have seen plenty of these go bad but never stuck in the fast idle position before. So now who knows where i can get a new fast idle solenoid?
Justin Bennett
Dec 30, 2016 09:37 PM
LSO1123
Dec 22, 2015 01:29 AM
Prototypemech
Dec 13, 2013 09:10 AM
Bigdix
Jan 29, 2011 09:27 PM
brentleedragon
17
Oct 23, 2008 12:27 AM
