Which flywheel do I have?
Old Oct 24, 2013 | 09:16 PM
Whisker's Avatar
Whisker
I have a 92 7.3 IDI with a ZF 5-spd transmission.
How do I know which flywheel do I have so I can get a new one?
Thanks
Old Oct 24, 2013 | 11:15 PM
zloetakoe's Avatar
zloetakoe
Take off the inspection cover at the bottom of the bell housing. You should be able to look in and "inspect" what flywheel you have. Ebay had the best deals on flywheel that I found. Was able to replace clutch, flywheel, and bearings for about 300.
Old Oct 25, 2013 | 09:12 AM
Whisker's Avatar
Whisker
Thanks for the reply.
I've had the engine out before, so I know how to look, but I don't know how to tell the difference between a single mass and a dual mass flywheel. Any tips?
Old Oct 25, 2013 | 12:16 PM
Chevy_Eater's Avatar
Chevy_Eater
A dual mass has springs in the flywheel itself, sorta looks like a combination flywheel & clutch disc in one. If the flywheel looks like a standard solid flywheel then it is a single.
Old Oct 25, 2013 | 06:59 PM
rustynail84's Avatar
rustynail84
if there are bolt heads on engine side about middle of disc face, it is dual
540milotalon
16
Sep 20, 2009 10:35 PM
Chumbucket
Dec 7, 2006 04:39 AM
912504x4
Oct 31, 2005 06:19 PM
unclecrusty
Mar 3, 2004 07:34 PM
