Please help!
Old Oct 23, 2013 | 05:50 AM
jp1096's Avatar
jp1096
Please help!
Hey everyone, my 04 excursion has been idling very rough at stops, and now all of a sudden it shutters really hard at around 50mph. I hooked up my computer and got ALL these codes, please help me start somewhere!!
P0269
P0275
P0341
P0401
P0671
P0674
P0675
P0676
P1260
Old Oct 23, 2013 | 06:19 AM
big inch's Avatar
big inch
It is most likely injectors. First thing I would do is verify fuel pressure is at least 45psi under a load.
Old Oct 23, 2013 | 06:23 AM
78fordman's Avatar
78fordman
Could be a FICM issue you too, check outlet power with koeo, idle and 2k rpm. Should never fall below 45 vdc.
Old Oct 23, 2013 | 06:35 AM
bismic's Avatar
bismic
IMO it looks like you have an electrical issue also - possible from your security system (PATS system perhaps)
Old Oct 23, 2013 | 06:45 AM
npccpartsman's Avatar
npccpartsman
Looks like 2 injectors and 3 glowplugs and/or glow plug circuits. I'd check the FICM to insure proper cold and/or starting voltage along with load testing the batteries (separately/unhooked).
I'd address the glow plugs while I had the valve covers off doing injectors. The circuits and plugs can be tested with a DVOM. I'm wondering also if one of the CB codes is caused from a rough cold start, but still sounds like an injector when it's hot/running.
Regardless, it will take a little detective work to narrow down your problem.
Old Oct 23, 2013 | 06:46 AM
bismic's Avatar
bismic
What is the P1260 all about (P1260 Theft Detected, Vehicle Immobilized) ?? This code is only thrown when the PCM sees an incorrect signal or no signal at all from the chipped key.
+1 on load testing batteries.
You had a previous post on a chipped key, but it looks like that was on an 04 F350 DRW. Are you using an aftermarket "chipped key"?
Old Oct 23, 2013 | 07:06 AM
JaySVX's Avatar
JaySVX
Those codes look to me like FICM as well. Low voltage on that can cause all sorts of things to misfire.
Old Oct 23, 2013 | 07:12 AM
npccpartsman
It's only 2 injector codes.
2006powerstroke90
Apr 22, 2017 05:45 PM
stevenjf88
Nov 25, 2015 08:11 PM
Hollywood691
Mar 9, 2015 12:37 AM
Lavern
Dec 26, 2012 06:53 PM
Aggie05
1983 - 2012 Ranger & B-Series
May 28, 2008 05:50 PM
