Sponsored by: Real Truck
Charging Problem Solved quick write-up
Old Oct 21, 2013 | 08:14 PM
dilan73's Avatar
dilan73
well I'm putting this up for those who may be having this issue
my trucks a 99 250 5.4 crew one alternator
I was having a charge problem but battery is new and topped off alternator tested good at advanced auto what then?
well after plenty of research and after the battery, terminal connectors, starter solenoid and Alt turned out ok. looked at fuse links in the alternator harness which on this truck wasn't so big about 3 feet or complicated to take off just unplug everything and remove it.
So first visually trace wires from Alt to battery area where they connect to starter solenoid. with battery removed remove wires and from solenoid and inspect the fuse links to look for burn marks and cuts then feel them do they feel like they have wire in them or do they feel like hollow tube all soft and rubbery which may be a burnt out wire.
well in my wire harness there were 3 fuse links at the connection point. Two 12ga and one 18ga that connected to them. the 18ga had completely corroded and was nothing but green powder. to check i had to cut and peel the shrink tube it and it was the connection point that was gone so at least it was not caused by some short somewhere.
went to the store picked up 18ga and some same size ring connectors that were self soldering shrink tube. made the sect and installed the new fuse link tested for continuity and good to go. installed back in the truck and all was back to normal. here are some picks
Old Oct 21, 2013 | 08:17 PM
dilan73's Avatar
dilan73
continued
more pics............
Old Oct 22, 2013 | 06:15 AM
RV_Tech's Avatar
RV_Tech
The thoroughness of your troubleshooting and the professionalism of your repair impresses me!!
Steve
72camperspecial
May 28, 2013 09:12 PM
hndacr
Jan 17, 2011 09:39 AM
rdct
Modular V10 (6.8l)
Mar 16, 2010 05:39 AM
fzeed
Dec 1, 2008 11:42 AM
dgalloway
Jan 5, 2005 08:27 PM
