Wiper park position
Old Oct 21, 2013 | 07:29 PM
trilogymac's Avatar
trilogymac
Wiper park position
Good evening.
New to the forum. I just purchased a 1977 highboy. The body is solid, runs good, drive train is in nice shape but it needs a few things so...
The wipers operate properly except they park in the full up position. I haven't torn into it yet. Figured I would ask first. What is the fix?
Thanks,
Trilogymac
Bill
Old Oct 21, 2013 | 07:56 PM
riverguideguy's Avatar
riverguideguy
i did a search and found this thread hope it helps https://www.ford-trucks.com/forums/6...dont-park.html
Old Oct 21, 2013 | 08:06 PM
trilogymac's Avatar
trilogymac
RGG,
Thanks for the help. I had searched and found that thread as well. My problem is that they always park in the same position, up. It seem like an arm or the motor or something is indexed wrong. Although that is a WAG.
Old Oct 21, 2013 | 08:56 PM
fmc400's Avatar
fmc400
MSEE
The positional switch inside the motor could be bad. When you turn the wipers OFF, the wipers actually keep getting power - then a switch inside the motor cuts itself off once the wipers lie down.
Old Oct 21, 2013 | 09:12 PM
trilogymac's Avatar
trilogymac
Mine keep getting power and goes thru a partial cycle like you said, but park up rather than down.
Old Oct 21, 2013 | 09:30 PM
mikeo0o0o0's Avatar
mikeo0o0o0
It's possible the arm on the motor is installed 180 degrees off.
The first picture is how the arm should be positioned, the next is how its assembled.
Old Oct 21, 2013 | 09:35 PM
trilogymac's Avatar
trilogymac
Mike,
Good evening.
I thought that might be the case. Thanks for the pics and I will check it out tomorrow.
Best,
Bill
Old Oct 21, 2013 | 09:54 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I bet you need to remove the outer wiper arm assembly (flat tip screwdriver), do a normal key on, run wipers and shut them off.
The reinstall them on the drive stud (thing sticking thru the cowl) in the correct position. Down....
Old Oct 22, 2013 | 07:00 PM
trilogymac's Avatar
trilogymac
Mike,
Good evening.
Yup! 180 degrees out.
Thanks,
Trilogymac
Bill
Old Oct 22, 2013 | 07:19 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by trilogymac
Mike,
Good evening.
Thanks,
Trilogymac
Bill
....... Thanks for the update.
BTW, welcome to FTE. Lots of good people here.
phoneman91
64
Feb 2, 2025 05:40 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Apr 26, 2016 05:50 AM
Grannygear
1997 - 2003 F150
Jan 10, 2009 12:32 PM
4byford
Electrical Systems/Wiring
Jan 7, 2007 06:23 PM
gskett
Jun 13, 2004 05:54 AM
