What causes bent pushrods?
Travis, by definition in engines, Power Band is the range between peak torque and peak horsepower. I see you HP numbers (is 518 @ 2800 your max HP), so to determine your power band we would need to know your max torque rpm. These rpm numbers would establish your power band. Max torque RPM to Max HP RPM.
What I've called my "power band" is my truly usable power range for doing work. I'm not going to pull in low rpms where I have more torque.. I'm going to pull where I have horsepower. I didn't know that's the true definition of the power band though, good to know.
- I have been told by a modding mechanic (who does not know what I put into the truck) that he felt my truck was putting down about 450 HP during a test drive - in my DD tune. I thought he was misjudging it by quite a ways because 400 HP is allegedly max for the fuel quantity of these injectors. I do confess proper air and gearing can make better use of the fuel, and I have not been on the rollers yet. Why do I not get on the dyno? Woodnthings got on the rollers last year with his stock injectors and decent mods - 400 HP. I don't trust the calibrations on the dynos from location to location. I look at the build way more than the roller numbers. Joey and Palmer slap some serious spin on the street. Our quaint 160/100s are impressive, smooth, and reliable... but not needle-benders. More RPMs can certainly raise the HP numbers, but that's for the sake of a higher number on a display or graph. We can't compare that 4000 RPM number with all the other trucks limiting to 3200 RPM.
- 34/35 PSI is about where my turbo flatlines, and I know it's capable of more. I have two very tall suspects in the lineup - my intake is not rated for this kind of air flow and I'm sucking in the filter minder with a fresh cartridge. I'm working on that now. The other suspect is far more controversial - the 4" exhaust. More power can "push through" the 4" pipe, but it has a problem with velocity - the velocity in the pipe is too high and flow suffers above a certain point.
- Your HPOP can handle those sticks, I'm almost certain of it. I have seen your issue countless times - I had it as well. I have one sure-fire cure, if the original issue is what I think it is. If you want, send me a PM regarding the HPOP numbers (AE data during a WOT run would be fantastic) and I can share some graphs and charts - minus the easel.
- 4000 RPM is becoming the norm on newer diesels, but I'd bet good money that would take the long life reputation away from the diesel engine. Diesel-powered boats of yore cruised at 1800 RPM, and they would get insane hours out of those engine. We're up to 3200, thanks to turbocharging. I think it was Caterpillar that changed their policies on warranty and maintenance recommendations. They no longer look at running hours - they look at fuel consumed or total revolutions (I can't remember which). Higher RPMs shorten the time between maintenance cycles either way. While I can't remember any specifics at all, the concept really caught my attention.
Edit.. also, on the street I can hang right beside a tuned 6.4.. I don't know how savvy you are there, but a deleted/tuned 6.4 regularly dynos 575-590hp.. he and I hang side by side from a roll, but my truck is quite a bit lighter than his '09 regular cab too. Those newer trucks a pretty heavy
I don't know what happens in the real world (re pushrods), but I don't see a lot of pushrods bending in the virtual world of FTE. We don't do 4000 and many of us discuss the best oils and change interval. It doesn't sound like your friend is one of the FTE brothers, so he may not be privy to proper care and feeding of our beasts. For all we know, he was running hard and fast, and accidentally hit the OD button.
I must admit, dieseling across the country has exposed me to a new land-based experience that I had no idea I would enjoy. I don't enjoy wrenching my weekends away for a year, in hot pursuit of a proper-running engine... but things have finally stabilized and now I'm Buck$Zooka blasting for a last push to wrap up some annoying details.
Once Stinky is done, I can aim that Buck$Zooka back at the water again. I'm considering a diesel lobster boat, now that I have a comfort zone with how a diesel works. A trawler is usually to big to tow.
Back to the topic, I think we can agree the higher RPMs with turbodiesels invites the type of damage not seen on diesels of the past. One way to combat this is to have a tuner put rev limiter on the tunes... but I'm pretty sure this is already done.
But after thinking about it for awhile I have a couple of ideas.First of all on these 7.3's I don't you see many push rod issues with stock trucks or truck with stock tunes driven by old guys that don't run higher rpm's having this problem. I think the issue comes into play when you are running a modded engine/tunes with higher boost and higher rpm's. I would bet that this is more of an issue with younger guys who want to hot rod these engines.
Now speaking of young guys who want to hot rod or beat the crap out of everything they drive. Believe it or not I was once a young man who beat the living crap out of everything I drove and doing so I have bent, broke or blown up just about everything. And in my experience with bent push rods (Which has been quite a few !) All on gasser v8's in cars and boats. Sometimes it was due to lifter, rocker arms, bent valve, crappy weak stock push rods, too much valve spring pressure and almost always high rpms.
It has been about 3 yrs now that I have been trying to learn all I can about these 7.3/ T444E and what makes them tick. The one thing I have never liked on these engines is the stock rocker arms. I see guys addressing the issue of push rods and valve springs. But never do I see anyone going with upgraded valves with a 4 angle valve job (to deal with seat pressure) or going with roller rocker arms. I am a big fan of using roller rocker arms on anything I have build in the past and not just high preformance or anything I want to last forever.
Roller rocker arms help reduce stress/ pressure from the valvetrain and push rods.
But in this case I would say too many rpms and bent valves with worn guides is causing the issue.
