which is larger? exhaust or intake valve
Intake valves are larger than exhaust valves. But the rockers and pushrods are the same for each, so I don't know why the valve size would matter for the purposes of your statement. And if you were to follow the ports to or from each valve, you should be able to tell very easily which is which.
Unless you are just curious, it's doesn't matter. The rockers and push rods are hydraulic and as Wayne mentioned, all the push rods are the same size and length - or at least they should be.
Yo should be able to drop them in, and set the assembled rocker arms on top and bolt them down - evenly, a little on each bolt at a time.
Valves themselves, larger and smaller, yes. Hydraulic pushrods and rockers - don't think so - same size.
He's installing pushrods and rockers.
PS Intake valves are larger on the 351M and all "Modern" Ford Big Block Engines.
Sorry - I was having a major senior "DUH" moment. Realized it when I looked at the head and followed the exhaust port back to the valve. I was getting ahead of myself thinking about adjusting the valves . . . snugging down 5 of them, then rotating the crank 180 and doing 4 more, etc. etc.
Yes, non adjustable . . . you snug them down a few at a time; in 3 steps, rotatingthe crank 180 then 270 degres. All this because I cant get 3 broken exhaust studs out of the heads. Might as well pull off the heads and take them to a machine shop now before the motor goes in. Man, I haven't pulled off heads in maybe . . . 45 yrears ? Good Golly Molly !!
1986F150six
03-26-2015 01:10 AM
fordfan28
07-28-2006 07:54 AM
