170f running coolant temp
Old Oct 20, 2013 | 10:53 PM
78fordman's Avatar
78fordman
I recently purchased a scangauge just to keep an eye on things and noticed that it only gets up to 175 max when running 70. It never cools down under 170 at idle. Is this a big deal besides being out of spec? Are there mileage, performance or longetivity losses or advantages with running it cooler?
Old Oct 20, 2013 | 10:58 PM
jswartz84's Avatar
jswartz84
You might see a mpg loss. Not too sure about performance. If your cold soak temps look fine I would go ahead and replace the thermostat.
Old Oct 20, 2013 | 11:01 PM
BLADE35's Avatar
BLADE35
its going to clog the EGR Valve and intake manifold Poor MPG as mentioned
Last time my thermostat ran that cold I replaced it and my MPG went up quite abit
Also the EOT don't mean as much until ECT is brought within Spec
GOOD Point on Cold soak Temps ^^^Check that
Old Oct 20, 2013 | 11:04 PM
78fordman's Avatar
78fordman
I installed a new oc about 10k mi ago. Right now I am at 175 ect and 190 eot. But like you said those are useless numbers until ect is 190. I will order a new stat and probably a coolant filter to boot. Thanks for the help.
Old Oct 20, 2013 | 11:49 PM
BLADE35's Avatar
BLADE35
Iv had the Best luck with OEM thermostats
ajg617
Sep 7, 2014 03:26 PM
danocross
Feb 5, 2014 07:03 PM
oxt127
Nov 27, 2013 07:41 AM
billbot
Jul 8, 2012 08:48 PM
KRDiesel
Jan 22, 2008 05:34 PM
