Low coolant temp
Old Nov 26, 2013 | 11:32 PM
oxt127's Avatar
oxt127
Low coolant temp
Just noticed my last two trips my coolant has been running at 175-180 and oil at 185. Going up hill on the interstate coolant will go up to 190 oil 195 but within a mile of letting off or goes back down.
Could be a coincidence that I just loaded new xstreet tune from IDP. Or its the first time this year we've had cold temperatures in PA this year.
Old Nov 27, 2013 | 05:40 AM
npccpartsman's Avatar
npccpartsman
Your coolant temps should be closer to 190 consistently. I think your thermostat is bad. It has nothing to do with the street tune. Cooler engine temps will also cause you loss of fuel mileage.
Old Nov 27, 2013 | 07:33 AM
oxt127's Avatar
oxt127
That has been my thought also, just makes you think twice when you put things together. And the drop in mpg had me slightly confused. Guess i know what my holiday will involve.
Old Nov 27, 2013 | 07:41 AM
npccpartsman
It will take you longer to drain and refill the coolant than change the thermostat. Use Motorcraft part# RT1169 and you'll be done in an hour or less.
DeeJayWoody
Jul 19, 2014 08:12 PM
scarty111
Feb 8, 2014 01:57 PM
BryanStein
Jul 27, 2013 11:02 PM
azchris
May 19, 2011 03:03 PM
richrob
Feb 3, 2011 06:11 PM
