ECT/EOT in cooler weather
Old Dec 9, 2011 | 12:52 PM
danocross's Avatar
danocross
Just got a scangauge so definitely a new guy to all the values. I understand that you should probably not judge your delta on the ECT/EOT issue until your coolant gets to 190F. Is that the standard to judge on? Having never monitored these values before, I sit around 175F after a 20 minute or so drive, but it has been cool for Tucson lately, maybe that is impacting that number. It is the original thermostat also.
Old Dec 9, 2011 | 12:58 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
That is pretty low on the ECT. It takes my temps to normalize after about 15 miles at highway speeds. And, my temps going to work right now is hovering around 30*f. And my temp will reach and hang at 190*. My EOT runs up to 195*
Old Dec 9, 2011 | 02:40 PM
jetact's Avatar
jetact
Agree with amdrivin, seens a bit low. Just ran down the freeway this morning and it was 33 here. I run ECT 190 and EOT 192-194. It was flat road. Running between 55 and 70mph
Old Dec 9, 2011 | 02:48 PM
Ricson's Avatar
Ricson
My trucks coolant was running 176 to 183 depending on outside temp. last weekend i changed out the thermostat and now it runs 189 to 190
With the old or new thermostat once the coolant temp. stabilized the oil temp. was within 4 degrees of the coolant temp.
Old Dec 9, 2011 | 03:58 PM
onuredneck707's Avatar
onuredneck707
I just had the oil cooler changed and mine hasn't been above 180 since the change. Its in the 30's here...
Old Dec 9, 2011 | 04:05 PM
danocross's Avatar
danocross
I have been driving in mid40s temps so the lower ECT is a reflection of the thermostat probably. The delta has been good, within 8 max.
Not being smart enough to know the effects, is the low ECT enough to say change the thermostat, and why would that be beneficial?
Old Dec 9, 2011 | 04:07 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I knew mine was running a little cool but going to work this morning (28*) ECT maxed out at 175*. New thermostat for me this weekend.
Old Dec 9, 2011 | 04:19 PM
69cj's Avatar
69cj
Diesels have no spark plugs and therefore rely on compression and heat for detonation once the glow plugs turn off. Ideal operating temps for the 6.0 is 190 to 204 range cruising on level ground after 15 to 20 miles on the highway. Lower temps can affect mileage, performance and emmissions. They can also cause carbon build up which can affect other vital components.
Old Dec 9, 2011 | 06:29 PM
BLADE35's Avatar
BLADE35
You read my mind rusty stopped by Ford 2day and picked up an OEM thermistate Looks like were Both gona have some FUN this weekend
And even though my temps have been arpound 173- 175 ECT my oil cooler is still 178- 180 EOT
The ECT vs EOT should be nice and tight regaurdless of ambeint temp or bad thermistate
Old Dec 9, 2011 | 06:49 PM
danocross's Avatar
danocross
So I took it out for a test run, about 15 minutes running 75-80mph on the freeway after about a 10 minute warmup getting to the freeway. Mostly sat around EOT 192, ECT 182, both would drop some to 187-189 and 177-179, that was it. 60F outside...
So I guess a thermostat is in order, any other comments with that spread? I was thinking safety so I didn't stare down the Scangauge but there may have been one time with a spread of 12.
Old Dec 9, 2011 | 06:58 PM
69cj's Avatar
69cj
Do the t-stat 1st and see what you have. When you do more than one thing at a time you don't know what did what.
Old Dec 9, 2011 | 07:32 PM
Rusty Axlerod
My oil temp comes up behind my coolant temp and kinda chases it after the truck warms up. Generally the coolant climbs when I'm pulling a long hill and the oil creeps up some, then after breaking over the top of the hill the coolant begins to drop as the oil is still rising from the pull up the hill. I have seen empty EOT/ECT deltas of 18* degrees when the terrain works out like that. Flat and level at 65mph, my spread is a pretty steady 11*. If the schedule works out, I hope to do coolers (both) over the Christmas break. I tow a 5th wheel camper and I saw some BIG numbers towing uphill back when the weather was hot. Highest ECT was like 228-230, EOT 240-242. Coolers are still good at 11* delta and I know it's gonna be hotter pulling a load in hot temps, but I didn't like those towing numbers.
I didn't make it to the dealership before they closed so it looks like an aftermarket 'stat for me(first AM engine part since I got the truck) . Might be interesting to compare temps next week sometime and see if there's a difference
Old Dec 9, 2011 | 07:42 PM
Ricson's Avatar
Ricson
Running 80 mph my temperature spread opens up to about 8-9 degrees.
Old Dec 10, 2011 | 01:29 AM
Gmangh15's Avatar
Gmangh15
My ect was around 180 today and my eot was around 220. What does that mean?
Old Dec 10, 2011 | 07:07 AM
Rusty Axlerod
According to the TSB the ECT should be at 195* when taking the measurements but spread should be 15* or less. 30* difference between oil and coolant temps is not good. You can try flushing the coolant system. It has helped some trucks reduce the spread and really should be done anyway before changing the clogged up oil cooler. Many guys do an EGR delete or an aftermarket EGR cooler at the same time, unless you have the early ('03-'04) round EGR cooler. Driving the truck with the oil cooler clogged up reduces coolant flow to both EGR and oil cooler an one or the other may fail. Oil cooler failure allows oil into the coolant system and makes a big mess and a lot more work to repair. EGR cooler failure allows coolant into the intake and causes steam out the tail pipe, overheating, head gasket failure and can hydrolock the engine by filling a cylinder with coolant. Starting a hydrolocked engine can bend connecting rods and cause sever engine damage.
I would flush it ASAP and see if that helps ( it may not).
