Shift kit 4r70w
Old Oct 17, 2013 | 09:52 AM
FordYoungGun35's Avatar
FordYoungGun35
Shift kit 4r70w
96' F-150 5.0 (not stock) 4x4 3.55 gears. Looking into a shift kit, in the future I will be changing the gears to 4.10. Has anyone used this kit http://www.summitracing.com/parts/tr...ion-type/4r70w or one like it? The truck rarely goes offroad, doesn't pull anything and also rarely hauls anything except for the occasional 4 wheeler. This is a weekend cruiser/hotrod/toy/project. Is this something I can do on my own? I haven't done it before but I was able to do an engine swap on my own so I have a decent amount of DIY
Old Oct 17, 2013 | 03:39 PM
96_F250_Deezal's Avatar
96_F250_Deezal
**Never, EVER put a trans-go kit in a 4R70W**
here is a quote from Jerry Wroblewski (former Ford Engineer that help design the 4R70W)
Having helped design and worked on the trans that's in your car/truck and being the Jerry of the Jerry Mod, TransGo=bad. Here is why.
Once upon a time, oh 10 years or so ago, a higher up at the Blue Oval mandated to us that we make the transmission shift out of manual low gear into 2nd even if you didn't move the shifter. Kicking and screaming we complied. Starting in the late 90's we were able to change this back due to early retirement packages.
Along comes TransGo trying to be hero. They are going to change a whole bunch of stuff in the valve body to prevent the trans shifing out of manual low. All the shift valves get replaced, the solenoid pressure regulator valve, the manual valve, etc. All of this is done in an attempt to prevent it from shifting out of manual low and a few things like that. They are trying to take the control away from the EEC and put it in the trans. If you want to do this, buy a manual valvebody and be done with it.
Here's the problem.
TransGo doesn't realize there are things called production tolerances and stack ups. About one in every 20 TransGo kits won't shift. I have talked to some people on this board that have had this problem. Why doesn't it shift? They cannot account for all the variances in the valve body when trying to do something mechanically that should be done electronically. This is bad, very, very bad. A 5% failure rate is out of control. How lucky do you feel?
Next issue with TransGo. They put a TV pressure blow off valve in the valve body right under the main regulator valve in the cover plate on the bottom of the trans. They claim this is to prevent TV pressure spikes which occur in the trans. I bet I have personally done the post morteums on 500 trans's and looked over a few thousand others. I have taken more pressure data than can be imagined. Guess what? I have NEVER seen an excessive TV pressure spike, ever. The main reason I think they did this is because again, they are trying to change something that should be changed electronically. They change the main regulator valve spring to have a "flatter" line pressure curve based on TV pressure. The problem with changing that spring, you make so much line pressure that you will explode the clutch cylinders. So they add this blow off valve to keep TV pressure to some set limit. Two issues here. One, this should be done electronically by asking for more pressure (there are reasons why this is bad, but I'll get to that later) and not trying to override the electronics. Two, if you ever take the pan off of a trans, even one that functions well, you'll see friction material in the pan, totally normal. What happens when one of these little pieces of material lodge in the blow off valve and have it bleeding off because it doesn't seat? I can answer that, you get your trans rebuilt.
While this may be enough to convince you, I'll give you one more.
Anyone out there with a transgo kit notice that when you are in 1st gear and mash it, about half way through low gear the car seems to really take off (this would be mainly on blower cars, not N/A cars), almost like a turbo kicking in? Ever wonder what this is? It's the freaking trans slipping from the shift kit.
There is a circuit in the valve body to feed the torque converter. Under certain conditions, high pressure demand, lower RPM (<3000) the production valve body will reduce the flow to the converter circuit to keep pressure to the clutches. TransGo gets rid of this nice feature. So you feed the converter circuit full bore all the time. While this is great if you have enough pump flow, but you don't until you really get the pump spinning. So what happens? The line pressure, hence the pressure to the clutches, drops and is not what it should be. In fact, in many cases it drops enough to make the forward clutch slip.
- Jerry Wroblewski
*If you want improved shifts, do the Jerry Mod, or JMod*
Old Oct 18, 2013 | 10:14 AM
FordYoungGun35
what about the B&M? and whats the Jmod?
Old Oct 18, 2013 | 04:08 PM
96_F250_Deezal
I have never installed a B&M kit, dont know
Jmod is better than any kit you can buy
Jmod your truck - https://www.ford-trucks.com/forums/1...ion-j-mod.html
link for original Jmod article - http://www.tccoa.com/articles/tranny...on/index.shtml
chapter 13-14 covers the valve body, the entire article is a good read
Jesse Gordon
Oct 9, 2016 01:58 PM
meborder
Oct 18, 2013 04:48 PM
barthel
Aug 13, 2011 03:22 PM
79CEEJAY
Jun 12, 2004 08:08 PM
the4by4freek
Mar 7, 2003 01:28 PM
