paint codes
Old Oct 9, 2013 | 06:19 AM
lafermedavid's Avatar
lafermedavid
paint codes
I m trying to find paint code (ppg) for Fords "Dark candy apple red metalic",,,can I pull that up on the internet or do I have to go to paint supplier... any help will be greatly appreciated
Old Oct 9, 2013 | 07:54 AM
scott79's Avatar
scott79
There are several sites to choose from but I normally use this one. You can see multiple years/vehicles. If you know the year and vehicle it was used on this should work for ya. I didn't look closely, but the only "dark candy apple red" I see is was on the 2008-09 mustangs. But its not metallic.
Color Codes - Ford Paint Cross-Reference
Old Oct 9, 2013 | 06:26 PM
lafermedavid
PC
Thankyou Scott
Old Oct 9, 2013 | 07:06 PM
scott79's Avatar
scott79
You are welcome, hope it helped ya!!
Thankyou Scott
Old Oct 9, 2013 | 08:08 PM
lafermedavid
paint code
It did.Maybe I should go to Ford and verify to be very sure,thanks again
Old Oct 10, 2013 | 07:06 AM
scott79's Avatar
scott79
It is always a good thing to double check stuff like this. Ford could probably confirm for ya. But, I would think that you could use a "metallic clear coat" over the dark candy apple red to give you that "metallic" look...? You could also get a sample of the paint code you are considering and see what you think of it as well. Good luck!!
Old Oct 11, 2013 | 10:46 AM
lafermedavid
paint codes
yea scott mustang color code,and yes on the clear metalics,,,that code you put up is right on
flatheadjohn
Apr 26, 2017 03:02 PM
green53
Ontario Chapter
Aug 1, 2009 08:43 AM
WEMII
Jun 11, 2008 09:14 PM
1badsupercab
Paint & Bodywork
Jan 28, 2004 10:03 AM
MikeRich-webber
Mar 8, 2003 11:01 PM
