E4OD ZF conversion
Old Oct 10, 2013 | 07:59 AM
jas88's Avatar
jas88
It won't turn on the CEL but there will be about 8 codes stored where the PCM is complaining that the transmission is not talking to it.
Old Oct 10, 2013 | 08:00 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Originally Posted by BenS77
What happened? My truck has been fine, not even a CEL. Still running the automatic E4OD computer.
Here's the thread that I started on this topic...
https://www.ford-trucks.com/forums/1...eed-truck.html
It was problematic enough that I went back to the 5-speed PCM with the leaky capacitor. I really need to fix that.
Old Oct 10, 2013 | 09:32 AM
myakkacracka's Avatar
myakkacracka
yea I figured the truck would be fine and im gonna have some trouble finding a ecu for a 5.8 OBD1 with a manual
Old Oct 10, 2013 | 01:55 PM
kawamatt2's Avatar
kawamatt2
It actually won't be that hard. You won't find an F150 with a 5.8L engine and a manual transmission. Ford didn't make it. You will have to look for an ECM from an F250/350 with the 5.8L engine and manual transmission. From my research, you have 4 options for ECM's:
F4TF_12A650_AHA (MAC0)
F4TF-12A650_AHB (MAC1)
F6TF_12A650_BJB
F6PF-12A650-ELA *******This PCM fixes a possible rolling idle problem with F4TF_AHA***** TSB 97-24-21
And if you need a VIN number (for searching purposes) of an F-Series truck with a 5.8 and manual transmission, 1FTHX25H5RKA50550
I personally went with the F4TF_12A650_AHA as that was all I could find at the time I did the swap. Obviously you are going to have to hunt ebay and/or junk yards to find these ECM's. I would like to have picked up the F6PF-12A650-ELA which is referenced in the above TSB as I have noticed in some instances I have the rolling idle as described.
Any of the above listed ECM's will work with all the systems in your truck and no codes will be set or CEL turned on. The only thing that is different, engine wise, from an F150 (w/5.8L) to an F250/350 (w/5.8L) is the thermactor system. On the F250/350 the catalyst is different and there is no provision to pump air into the exhaust downstream of the first CAT (and O2 sensor). Air is either pump into the heads (the exhaust manifolds actually) or dumped to atmosphere. The result of all this is that with an F250/350 ECM in an F150 truck, the air pump air will always be either sent to the heads or the exhaust stream and not dumped through the muffler on the passenger side fender when idling. I haven't experienced a problem with this behavior though.
If you are interested in actually making your truck factory correct from the wiring side (i.e. adding the wiring to the ECM from the clutch safety switch, fixing the backup lights, start string, and (if applicable) making the electronic shift transfer case function properly I would suggest viewing the below linked threads.
The first deals with completing the wiring from the clutch safety switch (on the clutch pedal) to the new manual truck ECM.
http://www.fullsizebronco.com/forum/...d.php?t=210790
The second talks about how to make the electronic shift transfer case (which was never offered from Ford along side a manual transmission on 96' and down F150's) work with your new manual transmission which no longer has the MLPS (manual lever position sensor).
ESOF Transfer Case and Manual Transmission - FSB Forums
Last edited by kawamatt2; Oct 10, 2013 at 04:13 PM. Reason: One of the links was wrong.
Old Oct 11, 2013 | 09:10 AM
myakkacracka
thanks for the info and the VIN I have a 95 F250 with the 5.8 not a 150 im just stealing parts off of a 150 because thats whats avaible at the junk yard. I no they exist but I have never seen a 5.8 with a manual so im thinking finding a ecu is gonna be kinda hard. and even with obd1 u all were having problems i dont think my cel has ever come on.
Bender99
Nov 6, 2010 06:35 AM
bmxstreet15
May 13, 2009 07:13 AM
1968F250429
Jan 16, 2008 11:34 PM
cjjeeper85
Aug 25, 2005 11:26 AM
MeBadDog2002
Apr 29, 2004 09:44 PM
