E4OD to ZF conversion
Old May 11, 2009 | 08:56 AM
bmxstreet15's Avatar
bmxstreet15
Ok, I have a 1997 F350 4x4 with the Powerstroke. I am wanting to get rid of the E4OD and replace it with a ZF 5 Speed. I have several questions. What transmissions can I use in my truck (year, model)? Also, what parts would I need to do the swap? I would obviously need the ZF trans, clutch, flywheel. What else would I have to get to make this clean and easy? Any help would be great. Also if you have any of the parts a may need please let me know.
Old May 11, 2009 | 11:44 AM
Brown Falcon's Avatar
Brown Falcon
You can use a ZF tranny from any 7.3
Don't use a tranny from a gas motor, as the jump from 2nd to 3rd is terribly large.
You will need the pedals and clutch linkage and master and slave cylinders from a 94.5-97 truck. Also may need to get a transmission tunnel from a manual truck.
You will have to change the computer also. Driveshafts will need to be changed.
Old May 11, 2009 | 12:07 PM
Neal 97 250's Avatar
Neal 97 250
Slave and master cylinders also. Basically you need a donor truck that you can get everything from.
Old May 12, 2009 | 09:48 PM
bmxstreet15
So would I be better off sinking the money into my E4OD? How much power can the ZF handle? This is the first automatic I have ever owned. I have alwas had 3, 4, 5 or 6 speed vehicles.
Old May 13, 2009 | 07:13 AM
barebackjake's Avatar
barebackjake
id put the money in the e40d im working on getting the parts to get a e40d or 4r100 in my truck. if pcs was done with there 5r100 controller i would be getting a 5r. im getting the pcs controller so it can be a semi auto trans.
brad_97stroker
Jun 4, 2014 04:22 AM
DougJ_1997PSD
28
Mar 27, 2014 10:02 PM
renegade14
26
Apr 14, 2010 02:25 PM
EMD_DRIVER
13
Jan 25, 2009 07:50 AM
