Radiator hose
Old Oct 5, 2013 | 04:54 PM
lemasters f100's Avatar
lemasters f100
Radiator hose
What would cause my radiator hose to heat up really hot after 1 mile driving at 45 mph. 1978 ford f250 400
Old Oct 5, 2013 | 05:17 PM
mikeo0o0o0's Avatar
mikeo0o0o0
How hot is "really hot"?
Are you talking about the upper hose? It's probably normal. That's the hot coolant return from the engine to the radiator.
Shoot it with an infrared heat gun and see what the temp is. Depending on what thermostat you've got, somewhere around 190 degrees is normal.
Old Oct 5, 2013 | 06:26 PM
lemasters f100
Even after only driving it a mile
Old Oct 5, 2013 | 06:33 PM
fmc400's Avatar
fmc400
MSEE
You have failed to answer the question.
mikeo0o0o0's Avatar
mikeo0o0o0
I would say probably. The hose will stay relatively cool until the thermostat starts to open. There is not much flow until this happens so the coolant in the block is absorbing all the heat.
I know on my daily driver, the first stop sign I hit is a little over a mile from my driveway. By the time I get there the gauge is already in its normal spot.
Are you having an overheating problem or is the hot hose something you just happen to notice?
Old Oct 5, 2013 | 06:36 PM
montana_highboy's Avatar
montana_highboy
Install an aftermarket temp gauge (preferably mechanical) and put your worries to rest.
Old Oct 5, 2013 | 07:51 PM
lemasters f100
Just something I noticed. Thought it was weid
Old Oct 5, 2013 | 07:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Once an engine reaches operating temperature the upper hose will be way too hot to touch, like I say around 190 degrees and it doesn't take very long to reach operating temp.
Sounds like you have nothing to worry about.
Like Montana said, if you have any doubts, install an aftermarket gauge.
Old Oct 5, 2013 | 08:19 PM
lemasters f100
Thanks for the help and I probably will do that
jmotor
Apr 23, 2012 10:30 AM
plgebbia
17
Mar 15, 2011 07:13 PM
jadmt
Dec 21, 2007 09:40 PM
muchocheko
May 24, 2007 09:35 PM
nsshull
Jul 14, 2006 09:24 AM
