Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
How hard to replace?
Old Oct 3, 2013 | 03:56 PM
takeitapart's Avatar
takeitapart
2002 v6 110k miles. Oil leaking from front of engine. I replaced the pan gasket recently. I think it is now the front/timing chain cover seal(s). How hard is the repair. I am well stocked with tools and reasonable DIY skills. Any thoughts/ advice/ pitfalls?
Old Oct 4, 2013 | 08:06 AM
tomw's Avatar
tomw
Just standard stuff as long as you don't mess with the timing chain & sprockets. I believe it can be done 'in car' if you want. The gasket set may come with a set of short chunks for the pan portion that is under the front cover. You would use RTV silicone {cat safe!} at the 'corners' where the three surfaces meet on re-assembly.
I think there may be a question about the crankshaft damper/pulley. I don't know if it comes with a woodruff key, or it must be positioned at TDC to 'time' the CKP sensor pickup. The 4 is a lot more touchy to take apart from what I have seen in the shop manual.
tom
Old Oct 4, 2013 | 10:25 PM
scott91370's Avatar
scott91370
Mine is doing the same. Haven't washed it off to be able to tell exactly where it's leaking from but with 276k miles it doesn't surprise me.
Take some pics if you do try it, please.
Old Oct 5, 2013 | 07:27 AM
captchas's Avatar
captchas
Guest
before you dig in to deeply, clean the motor and watch around the damper for the seal. with high miles they tend to dry out and crack and or wear a grove into the damper making the need of a new one a most.it is the most common leak in every brand car or truck that I've seen.
Old Oct 5, 2013 | 09:27 AM
scott91370's Avatar
scott91370
Thanks for the tip. Will do!
Old Oct 5, 2013 | 10:14 AM
tomw's Avatar
tomw
If the damper has a groove, you may be able to fit a sleeve over the grooved area and have a new surface to seal against. Aftermarket kits are available for some, but I haven't looked any deeper than that. I expect the sleeve is possibly glued to the original damper. I don't know if the damper is turned to reduce the diameter or how the thickness of the sleeve is accomodated, but they sell them.
tom
Old Oct 7, 2013 | 11:39 AM
takeitapart
When I first cleaned the engine I could not find leakage around the crank pulley. should I replace all at the same time?
Old Oct 9, 2013 | 10:38 PM
makuloco2000's Avatar
makuloco2000
Let me just say this... timing cover leak rh bank at T joint is very very common, and is the source of your leak. In doing this job you must replace the valve cover gaskets, timing gaskets obviously, and crank seal. So as you can see all the oil leak points will be seal with new gaskets anyway. Also you will need the intake gaskets. There is allot to this job, but its all easy stuff. You gave me an idea to do a video on this common problem on the next one that comes in the shop.
Old Oct 10, 2013 | 07:15 PM
scott91370's Avatar
scott91370
Is your shop in Ft Worth, Tx? Lol...
Old Oct 11, 2013 | 06:03 AM
makuloco2000
No Illinois sorry, there are so many people with so many problems out there but none of them I can reach because they don't seem to live in Illinois.
bigb609
Nov 21, 2011 05:35 AM
timbersteel
17
Nov 14, 2010 11:00 PM
ruff08
Oct 7, 2010 11:29 PM
02FX4Dude
Sep 29, 2004 05:04 PM
shel 67
Aerostar
May 15, 2004 12:40 PM
