6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Overheat?
Old Oct 3, 2013 | 11:57 AM
acschex's Avatar
acschex
Overheat?
Well, you see, we have a 2008 ford f-250 with the 6.4 powerstroke... Had the radiator issue... well, this is now the 3rd radiator.... Put the "T" from the Degas bottle.... Well I have a problem with it over heating. We have replaced the thermostats, as one was bad... all was fine and dandy... let it idle for 30 mins. and didn't overheat or anything. So he decided to take it on a good test drive, went through the city... everything was normal... so decided to take it down the highway @ 70..... well within 10 miles it started to overheat... pulled over, didn't shut it down, just let it idle for a few mins. temp went back to normal.... I DONT KNOW WHAT ELSE TO SAY!! WE NEED OUR TRUCK!!!!
Old Oct 3, 2013 | 03:30 PM
senix's Avatar
senix
I think we need a little more info. Did any check engine lights come on or messages in the message center?
Did you hear the clutch fan engage?
What is the coolant level in the degas bottle?
Old Oct 4, 2013 | 09:54 PM
StanleyZ's Avatar
StanleyZ
Originally Posted by acschex
Well, you see, we have a 2008 ford f-250 with the 6.4 powerstroke... Had the radiator issue... well, this is now the 3rd radiator.... Put the "T" from the Degas bottle.... Well I have a problem with it over heating. We have replaced the thermostats, as one was bad... all was fine and dandy... let it idle for 30 mins. and didn't overheat or anything. So he decided to take it on a good test drive, went through the city... everything was normal... so decided to take it down the highway @ 70..... well within 10 miles it started to overheat... pulled over, didn't shut it down, just let it idle for a few mins. temp went back to normal.... I DONT KNOW WHAT ELSE TO SAY!! WE NEED OUT TRUCK!!!!
Couple things come to mind. When u replaced the stats did you get all the air out of the system. it takes a while.
What is coolant level first thing in the morning, should be between the cold fill lines.
is the coolant the ford gold and a 50/50 mix with DISTILLED water?
Have you ever checked the nitrate level of the coolant? Should be checked each oil change and coolant additive added if needed.
When you over heated did you look at the degas tank, what was the coolant level then. Should have been well above the cold fill lines.
Did it puke out the cap? Did you pressure check the cap, the 08 stock cap is junk, get a new one. Cap should hold 16 PSI.
have you pressure tested the system. Should hold 16PSI. If the coolant is low or the pressure won't hold, the boiling point will drop as much as 45 degrees. That would make the truck overheat.
I guess you are looking at the dash temp gage, that thing is crap, get a temp guage. if the dash guage showed hot the truck was really hot, fan should have been sounding like an airplane, was it?
i just spent a couple months chasing coolant problems and in the end they were only a couple small exterior leaks. hope this helps.
Old Oct 8, 2013 | 08:19 AM
acschex's Avatar
acschex
We replaced the fan clutch because the fan was not cycling like it should. Well, we still have the overheat issue. I took it to the next town about 5 miles down the road, I lest as soon as I started her up, not giving a chance to warm up at idle. When I got there everything was good, so I turned around to come back. Well, about half way back she started to overheat, I slowed down thinking it would cool down quick like before, but it stayed hot! I stopped on the side of the road and it finaly it started to creep down. When starting to over heat, It crept a little past half and then the fan engaged and it went down a very little and stayed for a few seconds and then went past. We will check the cap, but now I am starting to wonder about a water pump? It shouldn't heat up that fast!
Old Oct 8, 2013 | 09:26 AM
brian1253's Avatar
brian1253
if you changed your radiator hoses you should look in your old hoses and there should be a spring in one of the old ones to keep it from colapsing when under load you need to put the spring in the new hose or talk to the dealership ( when i say talk i mean cuss out for bieng incompetent mechanics) to put it in. i cant remember if it will collapse sitting still but rev it up sitting still and look if it will colapse and squeze the two hoses one hose should have a spring in it
good luck
Old Oct 8, 2013 | 01:50 PM
StanleyZ's Avatar
StanleyZ
Yes, that sounds like a good possibility. Something is happening when you are under power that stops when you go to idle. You say coolant is not leaking, right? Water pump blades also sound like a possibility. I tell ya, these trucks are just too complex. Strange things can happen with them.
Old Oct 8, 2013 | 07:08 PM
senix's Avatar
senix
I think I would be checking the thermostats to see if they are hyperextended.
Old Oct 9, 2013 | 08:09 AM
acschex's Avatar
acschex
We took off the water pump.... This was our problem!! The impeller was shot! Thank yall so much for the help!! So it turns out that we had 2 different problems acting against each other! We will hopefully be able to get the new water pump on today and be back on the road!!!
Old Oct 9, 2013 | 09:59 AM
senix's Avatar
senix
This is probably the first water pump that I have heard of that was shot.
Some of the front covers yes but not the pump.
How does your cover look? Any cavitation there?
Old Oct 11, 2013 | 03:15 PM
acschex's Avatar
acschex
Just to update this post, We got the water pump on, and we are back on the road. Our overheat problems are solved!! Thank you!!
Ohh and one thing I forgot to post is that the truck does have 280,000 miles on it.
Old Oct 11, 2013 | 03:17 PM
acschex's Avatar
acschex
Oh, and to answer your question, senix, the front cover looks fine.
Old Oct 11, 2013 | 06:35 PM
StanleyZ's Avatar
StanleyZ
280,000, that's impressive. Is it stock? I guess you hot shot or haul cars or something like that, lots of highway miles.
NorthlandBass
Aug 9, 2016 02:13 PM
Melendez7.3
27
Jul 8, 2015 07:31 PM
blueeyedfordguy
General Automotive Discussion
Oct 12, 2013 03:46 PM
droid
Jun 20, 2005 05:14 PM
UglyF250
Mar 3, 2002 10:16 PM
