I have a 2009 f250 4x4 . When i make a turn and sometimes while driving the steering locks up. Sometimes i have to jerk it back. Sometimes it feels like i have no power steering . And some times its seems the gear box is stripped. I had it to a mechanic look at it and all the steering and suspention parts are good. The u joints are also good. There has to be a HUGE problem with this issue, due to know one having a steering box, even the dealer. Please let me know if you have the same issues. I have a truck that i cant drive
We had one case at work while yours is pretty new where the u joint on the steering shaft rusted a bit and were binding up. Strange tight and loose symptoms. We couldn't find it until we disassembled and the lower u joint was bound tight. We ordered a new one for the customer but an overnight soak in trans fluid freed the old one right up.
