Steering box
Old Mar 30, 2004 | 01:57 PM
farmb0y's Avatar
farmb0y
Steering box
I've got a '99 F-350 4x4 and my steering is loose already. I've located the problem to be with the steering box. For what I know about steering boxes, there isn't much to do to tighten it, but I'm not sure if there is anything on these trucks? I'm assuming the guy that had it before me tried turning the wheels a lot while sitting still which would cause a lot of undue stress on the steering box. If anybody has any ideas for a cheaper fix than buying a new/used steering box, let me know.
Old Mar 30, 2004 | 03:55 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
My steering is kind of getting loose too. Did your truck come with a steering dampener?
Old Mar 30, 2004 | 06:01 PM
farmb0y's Avatar
farmb0y
Toreador Diesel- Yea there is a steering dampener on it, and I know it's been replaced because it's been hit and bent before by the previous owner.
I'm just getting sick of chasing it around the road trying to go straight down the highway.
Old Mar 30, 2004 | 06:21 PM
Toreador_Diesel
To be honest, its beyond me. I think I'll need to call my dealer sometime tomorrow and ask a few questions.
Old Mar 31, 2004 | 07:41 AM
mueckster's Avatar
mueckster
Try adjusting the backlash in the steering box by loosening the jamb nut on top of the box and screwing the bolt(w/ allen head) in. Tighten it just enough to remove any slack there might be when moving the steering wheel side to side. The pitman arm should respond immediately to the steering wheel movement. Check to see if the steering binds when turning in either direction after adjustment. If it does, just back off the bolt slightly and retighten the jamb nut.
Old Mar 31, 2004 | 07:49 AM
skuteman's Avatar
skuteman
farmboy, you just made my case for NOT putting these big, fat, oversized tires on our trucks. They look great , but there is a price too be paid for everything . Hope you get your problem diagnosed and cured..., s.kuteman
Old Mar 31, 2004 | 11:28 AM
farmb0y's Avatar
farmb0y
I'll agree that oversized tires aren't the best for the trucks, but I wouldn't consider the tires I have on to be big, fat, oversized tires, they are 285/75/R16, just one size bigger than stock. And they get used when driving through mud and snow. The steering has been loose ever since I first got it, and I know the previous owner always had the stock size on it, so oversized tires don't have anything to do with the steering problem... this time.
Old Mar 31, 2004 | 11:57 AM
skuteman's Avatar
skuteman
..............Actually, I was referring to the Previous owner ....as a possibility , I just didn't state it correctly. At any rate , I hope you find an inexpensive fix as they trucks are expensive to work on and buy parts for. I , also have a 99 , 4x4 , PSD with 77k on the clock and the steering seems to be fairly tight . I run the standard , 265\75\R16's and have found them to be more adequate for my purposes, good luck with youre truck, s.kuteman
Tparkin99
18
Feb 13, 2022 06:28 AM
redrivergorge
13
Apr 23, 2017 11:43 AM
DanielT28
83
Jul 12, 2015 10:56 AM
JRSutton
Jun 29, 2013 02:18 PM
SproutW
1978 - 1996 Big Bronco
Feb 22, 2005 06:15 PM
