Sponsored by: Real Truck
03 E-550 7.3L IDM codes
Old Oct 1, 2013 | 05:53 PM
kmooservice's Avatar
kmooservice
help 03 E-550 7.3L with IDM codes clear all code, do in injector buzz test P1276 and P1275. Start truck and SES light comes on. shut off truck code IDM code go to KOEF and have P1272, P1273, P1275, P1276. just replaced vavle cover harness ohm wires to IDM put new IDM in. Truck shuts off while going down highway trun key off then back on an usally starts on it own Thanks
Old Oct 1, 2013 | 07:56 PM
Shake-N-Bake's Avatar
Shake-N-Bake
E-550?
Check the under hood harness bundle where it rubs against the left valve cover for signs of damage.
Did you go with OEM under valve cover harnesses? Did you replace the valve cover gaskets as well? Did you inspect the connectors for signs or arcing?
Old Oct 2, 2013 | 06:45 AM
kmooservice
yes oem harness and gasket, checked connector all look good, made up jumper wires from valve cover connector to IDM to see if the problem was in the engine harness. Didn't change anything
Old Oct 2, 2013 | 10:23 AM
Shake-N-Bake
When you changed your IDM, did you run the tests listed in this document?
What were your resistance readings?
File Type: pdf
Old Oct 2, 2013 | 12:57 PM
kmooservice
some reason i can't open that document try from 2 different pc
Old Oct 2, 2013 | 02:52 PM
Shake-N-Bake
Try this link instead...
» TB 103: 1994-03 Ford 7.3L IDM Replacement & Diagnostics
This is the home page for that website....lots of good troubleshooting info that may help you out someday...
http://www.gbreman.com/articles/
rollinblackcloud
May 1, 2014 09:10 AM
cstock
Jul 21, 2012 05:56 PM
leerider524
Feb 11, 2010 06:22 PM
daniel potter
Jan 14, 2009 12:48 AM
krzyk26
Apr 3, 2005 04:19 PM
