6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
blowing white smoke
Old Oct 1, 2013 | 04:40 PM
6.4smokinstroker's Avatar
6.4smokinstroker
blowing white smoke
Recently have had a sct livewire extreme on my truck and ever since put it back to stock put the dpf back on its been blowing white smoke got a p2452 and p1335 code but when you turn the tuner back on and turn the dpf off no more white smoke and no codes ??what could be causeing this? beyond confused ?? (the reason I took the tuner off is cuz im sell the truck and the dealership wants it stock
Old Oct 2, 2013 | 04:32 AM
bubbasz1's Avatar
bubbasz1
Look for sensor issues.
Old Oct 2, 2013 | 07:42 AM
GSchretter's Avatar
GSchretter
Odd behavior but to dump the truck go to another dealership and don't tell him about the mods.
They can fix it for 1/10 the cost.
I thought white smoke = water so switching between stock to lets say non-stock sounds like the EGR is back on in stock mode and your coolers might be leaking into the intake causing this issue.
Generally when you turn off the DPF the EGR is off also.
Hope this helps and good luck.
Old Oct 2, 2013 | 08:09 AM
senix's Avatar
senix
Might still have the old style EGR valve which has a coolant line going to it. Explaining the eating of coolant/white smoke issue.
So are we loosing coolant?
Old Oct 4, 2013 | 11:42 AM
TruckGuy27's Avatar
TruckGuy27
I'm having a similar issue. .. my 08 us stock and recently started displaying "cleaning exhaust filter" more frequently them before and randomly pours white smoke when accelerating
Old Oct 4, 2013 | 06:36 PM
6.4smokinstroker
its not using antifreeze and just switched pressure sensor no more codes but smokes only when it goes into cleaning mode confused !!
Old Oct 4, 2013 | 06:37 PM
6.4smokinstroker
smoke smells like raw diesel fuel btw !!
Old Oct 4, 2013 | 06:57 PM
bubbasz1's Avatar
bubbasz1
Does it go in regen all the time or only every few hundred miles?
Old Oct 4, 2013 | 11:49 PM
TruckGuy27's Avatar
TruckGuy27
What's Regan? So nothing to worry about?
Old Oct 10, 2013 | 01:27 PM
GSchretter's Avatar
GSchretter
Check oil level to see if it is making oil.
If so stuck open fuel injector.
Old Oct 17, 2013 | 11:55 AM
mcaramico's Avatar
mcaramico
found white smoke cause
Mine had been doing this and was unable to find cause till now. There where two problems with the truck. One was the exhast gas temp sensor was going bad and tricking the computer telling it needed more fuel dumping excessive fuel that could not be burned and blowing white smoke like crazy. The second problem was the water seperator was clogged with wax like goo. So bad that the sensor line was clogged and unable to tell me to empty it. So I was blowing water in the fuel I dont know it that had anything to do with the white smoke but it is not good. My mechanic told me not to use biodiesel anymore he said that is the cause of the waxy build up. But since he did those repairs I have no more white smoke issues and my mileage has went up about 2 miles per gallon. He changed the exhast gas temp sensor took off and cleaned out water seperator changed fuel filter checked balance on all fuel injectors which were all good and with tax it was $745.00 but well worth it not to be blowing smoke and wasting fuel. In no time I will have that money back in better mileage.
Old Oct 17, 2013 | 11:59 AM
mcaramico's Avatar
mcaramico
found the fix
Old Oct 17, 2013 | 12:00 PM
mcaramico's Avatar
mcaramico
found the fix
Old Oct 17, 2013 | 06:22 PM
slowmans's Avatar
slowmans
Did you return the truck to stock when you put the DPF back on?
04F250CC60
Dec 15, 2019 09:22 PM
Pridnjoy
Oct 27, 2013 04:00 PM
packer159
Oct 12, 2011 04:52 PM
nagorg
Jul 18, 2010 05:58 PM
powerstroke219
Apr 19, 2008 08:34 PM
