6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
white / Gray Smoke ??????
Old Oct 10, 2011 | 07:38 PM
packer159's Avatar
packer159
Question white / Gray Smoke ??????
Guys I need your Brain power here. I have a 08 f-350 with a H&S black maxx, cold air and 5in exhaust. After I drive the truck for a while (30 to 45 min) and let every thing get warmed up, I get a lot of white / gray smoke from the exhaust when the truck is at a idle after idling for 30 sec to 1 min. Once i accelerate for example taking off from a green light it stops until I hit a red light. I took it to my dealer and they said that its normal because the dpf would clean the smoke out before I removed it. I call B.S.
Old Oct 10, 2011 | 08:44 PM
R-T0r21on's Avatar
R-T0r21on
I agree to B.S. White smoke could be a couple things, but I would bet EGR issue. Are you slowly losing any coolant with no leaks seen?
Old Oct 10, 2011 | 10:37 PM
senix's Avatar
senix
Eating coolant is what comes to mind.
Old Oct 12, 2011 | 04:52 PM
StanleyZ's Avatar
StanleyZ
I'm not sure what the impact of the EGR being "Turned Off" would be but I do know that the Black max will allow you to disable the EGR without removing it. Could that be having some sort of impact. Do you have your's disabled?
04F250CC60
Dec 15, 2019 09:22 PM
Robil7
Jun 8, 2011 10:06 AM
WH 6.0
Aug 9, 2010 08:54 PM
Apalm84
Jul 23, 2009 01:15 PM
badbrad60
Oct 4, 2006 04:00 PM
