Help- lost boost while towing.
Old Sep 30, 2013 | 07:51 PM
IHbase's Avatar
IHbase
Climbing with indicated 25-30 lbs boost (normal) and blew odd the after cooler blue hose. Re-installed on side of road. Truck runs perfectly but boost will not go above 5-7 lbs and obviously low power.
Ideas? Still loaded and 200 miles from destination.
-Thanks in advance.
-Mike
Old Sep 30, 2013 | 07:55 PM
jswartz84's Avatar
jswartz84
Sounds like you have a leak in the boot. You can remove and inspect it, but pretty sure its torn. If you have some duct tape, that might help you get to the next town. There is a possibility that its not seated all the way also.
Old Sep 30, 2013 | 08:20 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
^^^^^Yes, check the boot.
Some have found they folded under the boot on the underside of the mounting. Check all 4 boots while you are there.
Old Sep 30, 2013 | 08:31 PM
big inch's Avatar
big inch
Usually a torn boot is pretty obvious because of the noise it makes, but that is the most likely cause of the loss of boost.
If it is not torn, you might check the map sensor hose to see if it is loose or damaged.
Old Sep 30, 2013 | 10:12 PM
BLADE35's Avatar
BLADE35
Well it Blew a Boot off what else did it Blew Out
Old Sep 30, 2013 | 10:27 PM
IHbase's Avatar
IHbase
Ok. Boot is in good shape- I checked. But I did re-install with the engine running because it had been running at WTO with 24-26k behind it on a pretty good climb- ECT was at 220 and I didn't want to shut it down hot.
After I restarted later, boost level and everything was back to normal. Pulls like a train again.
How hard should I torque the boot clamp? It says "do not over torque" and I have been paranoid about reefing it down, but obviously I did not have it tight enough after I upgraded boots (years ago) or it would not have blown.
Is there something else I should do when I re-install those boots that I have not done? Everything is dry and clean.
Thanks in advance.
-Mike
Old Sep 30, 2013 | 10:33 PM
mhoefer's Avatar
mhoefer
Torque is low, 12 lb ft, I think, hopefully someone will chime in with facts.
Old Sep 30, 2013 | 10:37 PM
IHbase's Avatar
IHbase
Yeah, I have the spec- and that is what I went to. But it blew so I must have done something wrong. -Mike
Old Sep 30, 2013 | 10:44 PM
BLADE35's Avatar
BLADE35
Clean it and Spray it with Hair Spray Install Clamp n Go
Iv never Torqed them clamps with torq wrench But I do Crank them pretty Tight
Old Sep 30, 2013 | 11:02 PM
IHbase's Avatar
IHbase
Hair Spray!!! Blade, you keep hairspray in your truck?!?!
Thanks for the advice. What about that tacky stuff for holding gaskets in place during assembly- would that be ok to use?
When you torque those clamps, do you end up compressing that spring all the way down?
I really can't figure why this one blew today- the truck has spent a lot of time loaded and climbing WOT at 3,000 RPMS since I upgraded the boots years ago- and the boot did not blow until today.
-Mike
Old Sep 30, 2013 | 11:35 PM
BLADE35's Avatar
BLADE35
LOL well I haven't had to use it but I know Lots of folks who Have
Silicone would Hold forever but would Kill the Boot if it had to come apart down the road so Hairspray works Greaty for this
I haven't used the Tackey stuff for gaskets but it sounds Fine
Folks just use the Hairspray cause it will hold But it can Also be Taken Apart fairly easy Just work a Screwdriver around the Boots if you need to take it apart down the road
I would have to Look but I do Tighten it down good
I bet my spring is Close to Compressed all the Way Im Shure I overtorqed it Some Im probably double torq spec
-Mike
Maybe worked loose over time or Boost psi was little higher IDK
Oil gets in there and Makes it all Slick so the Boot may slide off
Maybe a Few things that Lead to the Boot coming off just keep an Eye on Boost PSI for a Few Days Now especialy at WOT or when engine is Loaded and lots of Boost
You don't want to see over 28psi Boost
Also check MAP BARO EBP @ KOEO they should be the Same
Keep an eye on it you will be Fine
Old Oct 1, 2013 | 01:15 AM
IHbase's Avatar
IHbase
Thanks. I'll check these tomorrow AM and track down some hairspray. What will it tell me if those numbers are not all the same? I do not think that it is over-boosting. I understand that the factory gauge is not very accurate, but I have never observed it hit an indicated 30. It looks like 28 or 29 is the top end on the factory gauge.
-Mike
Old Oct 1, 2013 | 03:18 AM
bismic's Avatar
bismic
The factory boost gauge is accurate.
Old Oct 1, 2013 | 09:59 AM
big inch's Avatar
big inch
I use a little interior trim adhesive on the inside of my CAC hoses. My truck will hit 32psi when I lay into it.
anassar11
Apr 7, 2012 08:23 PM
PEI
18
Jan 29, 2012 01:37 PM
69Cobra
17
May 10, 2010 05:29 PM
bigpowerstroke
Jan 6, 2010 07:25 AM
zx250
Mar 23, 2006 06:44 PM
