Boost is Back!
Old Mar 22, 2006 | 06:12 PM
zx250's Avatar
zx250
Of the next Riffraff East
Boost is Back!
Finally had a local mech look for my oil leak. He found loose boots and slipped boots. Put them back in place and tighten all up. I think it fixed my leaks but I know it has improved my boost. I did not know how much power I have been missing until I got it back. Now I have a question, I have been running my wastegate unplugged. It seems to be opening up easier now than when plugged up. Any reason for that? I have tried it both ways and both opens but it does open more when unplugged.
Old Mar 22, 2006 | 07:37 PM
Kwikkordead's Avatar
Kwikkordead
Did you unplug the hose to the canistor or the electrical plug to the boost control solinoid?
Old Mar 22, 2006 | 08:03 PM
zx250's Avatar
zx250
I unplugged the red hose to the canistor.
Old Mar 23, 2006 | 09:41 AM
zx250's Avatar
zx250
I have had a chance to run wastegate plugged and unplugged. Can't seem to tell much differance. If anything it seems to open more with it unplugged. Also, I don't see as much black smoke when I get on it as I did before the repairs. What do you think?
Old Mar 23, 2006 | 04:02 PM
Pikachu's Avatar
Pikachu
The black smoke you were seeing before was probably from rich combustion caused by lack of enough air due to the leaks. Sounds pretty normal you'd see less smoke with full boost.
Old Mar 23, 2006 | 04:03 PM
PSNut's Avatar
PSNut
Are u sure your getting less boost with the wastegate disconnected;verified by boost gauge?
U should get less black smoke since u fixed your leak because your combustion
is cleaner with more air making it into the cylinders.
Nut
Old Mar 23, 2006 | 05:14 PM
zx250's Avatar
zx250
I am ashamed to say I don't have my gauges in yet. I am going by the sound of the wastegate opening up. I seem to hear it more when unplugged. Thanks for you input.
Old Mar 23, 2006 | 05:16 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
its dang near impossible to hear the wastegate open. over the sound of the engine as it opens, its almost inaudible. the wastegate is integral to the exhaust system, and it is a closed system. it doesnt make a hissing or wooshing noise. if you can hear it as i watch it open up, ill shake your hand.
Old Mar 23, 2006 | 05:30 PM
zx250's Avatar
zx250
Ok, maybe I hear something else. It is a whoosing sound at the end of a hard acceleration and let off.
Old Mar 23, 2006 | 06:36 PM
hink10's Avatar
hink10
That sound is air escaping back past the turbo when you let off the throttle. You really hear the engine "breathing" when you open the intake with 6637 filter. Sounds are always there, just don't hear them with the stock intake.
Old Mar 23, 2006 | 06:42 PM
zx250's Avatar
zx250
Thanks, as always I learned yet another thing about my beast.
Old Mar 23, 2006 | 06:44 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The wastegate, when installed and operating normally, starts to open at 5 pounds of boost, and remains open until you go below 5 PSI. When you disconnect and plug the red pressure hose, the wastegate remains closed until it is off-seated by boost pressure. On an unmodified wastegate this generally happens around 22-24 PSI. You create and sustain more boost with the wastegate disabled.
polosabre
Sep 29, 2014 08:17 PM
dothedew192
38
Oct 26, 2013 03:43 PM
Pocket
22
Nov 10, 2012 08:12 AM
2006powerstroke90
Nov 17, 2011 06:50 PM
megawatt00
64
Aug 25, 2009 06:16 AM
