Sponsored by: Real Truck
Need help with power window issue
Old Sep 30, 2013 | 12:15 PM
spongecop's Avatar
spongecop
Semper Fi
R/R of my CC (listed in signature) has had an issue since I bought it several years ago. Door lock actuator needs to be replaced so I figured I would tackle both while the panel is off.
Symptom: R/R window will only go down 1/2 to 1/4 of the way then slows down when using the master switch on drivers door. Sometimes wont go down at all. If I used the switch at the door it works fine (up and down). I can roll it up fine with the masterswitch.
Done so far: I have switched door switches and mastster switch with OEM part...no change. If I open and close the door then It works for a while which indicates a wiring issue in door jamb.
Question: Can anyone post or list which wires I can check (color etc) and or run a new section? I dont have any wiring diagrams.
THX
Old Oct 1, 2013 | 08:32 AM
spongecop's Avatar
spongecop
Semper Fi
anyone........?
300sflyer
Sep 14, 2021 09:53 AM
ShelbyHauler
Dec 27, 2017 03:26 PM
400Nut
Aerostar
Sep 6, 2012 02:44 PM
thbowen
Aug 31, 2010 10:29 PM
drew213F250SD
Aug 31, 2010 08:17 PM
