2008 F350 Window And Door Lock Problem
Hi folks,
I recently bought a 2008 SD crew cab F350. The left rear door has two issues. The first is the power door lock. It does not work on the switch on that door, or from the drivers door. The other 3 door locks work as they should.
The second issue is the power window. It will not work with the switch in the door, but does work fine from the drivers door.
Given that both of these issues are in the same door, I am wondering if there might be a loose ground wire somewhere? I have checked the fuses, and they seem to be fine.
Thanks for your help!
I did a bit of trouble shooting on the power window. I swapped the RRD switch [works fine in the right rear door] in the LRD and there was no change, it still did not work on the door. If I disconnect the door window switch altogether, the window will not work at all, even from the drivers door. So it would seem there is power there in the door itself.
Rear driver door found issue
Found this when I removed the boot from the door. Hope this helps someone else
hellmary
08-10-2013 06:23 AM
rolltide3006
07-07-2011 11:43 AM
FordF350Baby
11-14-2009 04:04 PM
