swapping '99 van engine into L99 SD
Old Sep 28, 2013 | 09:35 PM
lght1's Avatar
lght1
Question swapping '99 van engine into L99 SD
Hi
I just bought a '99 van engine minus the turbo to replace my tired, dusted engine.
What needs to be swapped over from the old engine to make this work? I have heard that some brackets may be different and that the right exhaust manifold is different in the van.
I will be using my own hpop and recent injectors for this new engine.
thanks
Old Sep 28, 2013 | 09:50 PM
BigAlsPSD's Avatar
BigAlsPSD
Originally Posted by lght1
Hi
thanks
That's pretty much it...Exhaust manifolds and up pipes, pedestal and turbo, oil cooler, spyder and possibly plenums if Early.
Old Sep 28, 2013 | 09:54 PM
lght1's Avatar
lght1
hi
i will be using my own turbo/pedestal. this is such a great opportunity to do up pipes so will do that as well.
can the van manifolds be used? i hate the thought of a broken bolt taking out the old ones.
Old Sep 28, 2013 | 10:15 PM
BigAlsPSD's Avatar
BigAlsPSD
hi
Exhaust manifolds?
They go the wrong direction unfortunately.
Old Sep 28, 2013 | 10:18 PM
lght1's Avatar
lght1
hi
how? i have never seen a van set up
Old Sep 28, 2013 | 10:56 PM
BigAlsPSD's Avatar
BigAlsPSD
They bolt on below the "log" where as the truck versions bolt above, I have a pic somewhere I will try to find.
Old Sep 28, 2013 | 10:58 PM
lght1's Avatar
lght1
hi
that would be appreciated. mine prob wont be delivered for at least a week or so.
Old Sep 30, 2013 | 01:44 PM
rat49f6's Avatar
rat49f6
Ive had the beat luck remiving manifolds when I cut the bolt between the head and the manifold
There is an opening there ... on the ines without openings try traditional method or grind off the bolt head
The manifold bolts usually seize to the manifold not in the head
Kyle_KleinSS
Aug 14, 2015 04:19 AM
JT250
Nov 16, 2013 02:57 PM
Kyle_KleinSS
13
Mar 15, 2011 10:00 PM
bren7176
Jan 31, 2010 09:42 AM
bigcountry560
Aug 17, 2006 11:51 PM
