engine
Old Jan 28, 2010 | 07:36 PM
bren7176's Avatar
bren7176
engine
Got a question, will a engine from a 99 e series 7.3l fit a 99 f series 7.3l and what is the difference . would i loose or gain anything by this .
Old Jan 28, 2010 | 07:55 PM
Izzy351's Avatar
Izzy351
Same engine. And you'll gain a van turbo!! A nice bonus!
Old Jan 28, 2010 | 08:03 PM
Bigcat350's Avatar
Bigcat350
Like Joe said same engine with a little better turbo. If your engine is good swap turbo's
Old Jan 28, 2010 | 08:04 PM
bren7176's Avatar
bren7176
okay , now whats the bonus of having the van turbo ? and everything is a direct bolt on then .
Old Jan 28, 2010 | 08:07 PM
Bigcat350's Avatar
Bigcat350
Joe will give you the Van turbo low down. He really likes his as alot of others do.
Old Jan 28, 2010 | 08:17 PM
bren7176's Avatar
bren7176
what im looking to do is swap my engine for a low mileage 7.3l out of e350 . if i did this what would i have to change over from my engine to the new engine
Old Jan 28, 2010 | 08:20 PM
Izzy351's Avatar
Izzy351
Bigger exhaust housing & wheel. The van has no room for an IC, so they made the turbo larger to make up for it (only on the exhaust size). The compressor side is stock. I'm running one with with larger injectors. You'll want tunes if you do put the van turbo on -- on a stock trucks it SSSSUUUUUUUUCKS.......... LOL
And since you have a 99, are these both late 99s or earlies or what??
Old Jan 28, 2010 | 08:23 PM
Izzy351's Avatar
Izzy351
Depends on the state of it being early or late. But if you want to swap late for late or early for early, just move everything over to yours, but you'll need your intake path & air cleaner since the e-series has no IC, and the air cleaner is in a totally different place.
If one is early and one is late 99, that's a different ball game...
Old Jan 28, 2010 | 09:17 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The oil cooler ends are different.
The fuel lines from the filter housing to the corners of the heads are different, but they will work on either engine.
The driver's side exhaust manifold is different too.
Old Jan 28, 2010 | 10:07 PM
bren7176's Avatar
bren7176
mine is a early 99 so would later engines be a pain to swap with? i also have a line on 2001 7.3 f series engine would that be a bit easier to swap in
Old Jan 28, 2010 | 10:19 PM
Izzy351's Avatar
Izzy351
No -- actually that is the better of the situations. You'll get the updated stuff, like larger injectors, 17* HPOP, turbo, manifolds, etc, etc, etc...
EDIT: You'll need a late spider though -- the van doesn't have that.
Old Jan 31, 2010 | 09:42 AM
bren7176's Avatar
bren7176
okay say I got the engine out a 2003 f350 , would i have to change the pcm or could i use mine . and all the wiring would work from the 99
