Possibly buying a van for the engine.
Old Aug 13, 2015 | 06:16 AM
Kyle_KleinSS's Avatar
Kyle_KleinSS
Hey guys I have a question here. Locally there is a van for sale I can pick up cheap. I basically just want the engine out of it. It is a 2001. I wanted the late 99 turbo set up off of it. Also I could use the injectors as extra cores when I upgrade mine on my truck. So my question is is this worth it? Do the vans not have the same set up as the SD trucks? If not what would I be missing for the late 99 set up? Also what are the other differences on the van engine? I can get this cheap so it is definitely an option to buy.
Old Aug 13, 2015 | 07:34 AM
carguy3j's Avatar
carguy3j
The vans had a different turbo. The compressor side is the same. The turbine side (exhaust) is larger (1.15 A/R vs 0.84 on the truck), and the turbine wheel has a different "trim". The van also has no wastegate, and no intercooler. The exhaust outlet housing is different, and you will need a $100 adapter to use the van turbo in your truck. On its own, the van turbo will have more turbo lag, but will make a little more power once it does spool. However, with supporting additional mods (bigger injectors,WW2 etc..), its reported that the lag is not noticeable. Do a search for "van turbo", as there are numerous threads on the subject.
I'm not sure about any other engine differences, van vs truck.
Old Aug 13, 2015 | 12:07 PM
carguy3j's Avatar
carguy3j
Another thing that occured to me:
Vans have no intercooler, and therefor I would assume no "spider". This is one of the things you would need to change, to upgrade from e99 to 99.5-03. So, you would need to source that elsewhere (more money). So, you're basically buying the van for a turbo and the basic long block, but would still need a number of parts from another vehicle.
Old Aug 13, 2015 | 01:40 PM
Bonanza35's Avatar
Bonanza35
If it's cheap enough I'd buy it anyway. Dose it run? And what kind of miles on it?
Old Aug 13, 2015 | 02:43 PM
Kyle_KleinSS
He has 1k on it. 300k on it. I am probably gonna buy it pull engine and scrap it. I can sell the e99 set up off mine and sell the hpop and what not. I should be able to break close to even then have an extra set of injectors for cores.
Old Aug 13, 2015 | 05:01 PM
snknby123's Avatar
snknby123
Any signs of dusting in the air intake? You can pull the engine cover off easy enough and take a look at the intake. If it starts well with no smoke and runs strong down the road I think it's worth $1K all day long. I'm seeing engines all over CL on the ground for $2k and you don't even know if they run!
Old Aug 14, 2015 | 04:19 AM
Kyle_KleinSS
If its still available in a few weeks I will buy it. I can definitely make money off it.
brandon_oma#692
Aug 3, 2017 04:35 PM
JT250
Nov 16, 2013 02:57 PM
carltonwebb
Jan 1, 2012 12:09 AM
7.3 Rocket
25
Nov 4, 2010 11:13 AM
tholt34
20
Jan 15, 2008 06:35 PM
