I'm pulling the front spindles off my D44 ('78 F250) for some needed bearing and U joint service. I believe it is running the same parts and grease Ford used in 1978.
I have the brake rotors off and have removed the 5 nuts holding the spindle. I cannot get the spindle to budge. I've tried tapping it around the edges with a chisel, a rubber mallet on the brake caliper mounts and floor jack + wood block under the spindle. No go.
Any ideas on how to get this off without hurting anything?
