rear bumper
Old Sep 27, 2013 | 05:55 PM
redrider8293's Avatar
redrider8293
rear bumper
hi guys im looking for a factory rear step bumper for my 1975 f250 as well as the mounting hardware not to sure if this is the right place on the forum to put this but I hope someone on here either has one or knows of one for sale
thanks tyler
Old Sep 27, 2013 | 06:39 PM
HIO Silver's Avatar
HIO Silver
Well, that's kind of a misnomer because bumpers back then were optional. And if one did choose a step bumper then the salesman usually pointed at one on a rack from an aftermarket supplier.
With that said, 75-lb. "dock" bumpers are on almost every Dentside in the salvage yards because not very many folks opted for the OEM "contour" bumper because it doesn't have nor is rated for a hitch mount while others opted to go post-purchase and buy/install one from a retailer. Even fewer simply never installed one.
So head the local 'yard with a Dentside and have at it. That's the best deal. Otherwise, buck up and get the popular step bumpers made by Fey.
Old Sep 27, 2013 | 08:45 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Like he said JY time, or craigslist or a ton of reproductions are made by FTE sponsors (NPD or BG) and or non sponsors like high $, low quality LMC and high $, high quality Dennis Carpenter.....
I got a chrome 79 step bumper off the c list for 75$ and smiled all the way.
Old Sep 27, 2013 | 08:52 PM
HIO Silver's Avatar
HIO Silver
And those genuine Ford license plate light cap, lense, and pigtail assemblies are about $45 each.
Old Sep 27, 2013 | 09:15 PM
77&79F250's Avatar
77&79F250
And it was a very big smile BTW....
Old Sep 27, 2013 | 09:27 PM
HIO Silver's Avatar
HIO Silver
I too smiled when I assembled up a pair from three different trucks. It's technically not correct for a Bumpside but that's where they are going.
Old Sep 27, 2013 | 11:48 PM
blue04.5's Avatar
blue04.5
And to think I just cut mine off today. A PO at some point welded it to the frame, another or the same bent it all up and another or the same painted while on the truck not minding to mask anything off, as you can see by the overspray on the quarter panels. I plan to keep the license plate lamp though has that nice Ford stamp on it
Old Sep 28, 2013 | 12:31 PM
TylerJ150's Avatar
TylerJ150
My back bumper is welded on as well and it's crooked as crap, how'd you get yours off right there by the gas tank? Everything I can think of involves heat and sparks so I'm really hesitant to get at it lol
Old Sep 28, 2013 | 01:53 PM
77&79F250's Avatar
77&79F250
If you have to torch or grind by the gas tank you can put a wet old blanket or towel to catch the sparks and have the tank full, that way less room for fumes.
Cut the bumper bolt head off on the outside of the frame, even I do not like to torch in between the fuel tank and the inside of the frame....
Sawzall is a good alternative to a grinder or torch if you can get it in there, or even an air chisel?
Old Sep 28, 2013 | 02:57 PM
TylerJ150's Avatar
TylerJ150
Good calls lol, I'm gonna have to try them. I have a full body shop's worth of tools at my disposal at school, I'll do that when I have the bed off to switch it. Of course depending on how things go I may even just pull the tank too and not even have to worry about it.
Old Sep 28, 2013 | 03:39 PM
77&79F250's Avatar
77&79F250
If you are pulling the tank to just pull it, since you are that far in, you might as well replace the sending unit, and clean the heck out of the insides.
And look the underside of the tank real well where the bottom support straps follow the curve of the tank, that is a common rust place.
And change the filler neck tube, having the tank off makes it easier to do the bumper, just do not get your bumper hardware installed backwards. Meaning have the nut on the tank side of the frame.
Old Sep 28, 2013 | 04:29 PM
TylerJ150's Avatar
TylerJ150
Well the fuel gauge doesn't work right now anyway so I'm sure it needs the sending unit anyhow.
The tank seems solid but a good clean out and paint isn't a bad idea either
I didn't mean to hijack the tread lol just wondered how he went about removing the welds without chopping the frame up.
Old Sep 28, 2013 | 05:50 PM
blue04.5's Avatar
blue04.5
For now i did it down and dirty. Cut it off with sawzall and left the tails welded tothe frame. Eventually it will be getting a roll pan.I did it right where i took the photo. There's plenty of room to cut it with every thing in place.
The Peddler
Jun 30, 2018 08:20 PM
beartracks
Sep 23, 2014 02:56 PM
haasfogle
Jun 3, 2011 10:06 PM
RIDER307G
Feb 8, 2008 10:23 PM
Thomasm67
Jan 4, 2005 08:20 AM
