Well in the process of doig the deed. The connector came out of the cooler. Took it to the dealer and talked with parts guy and a tech. They do sell just the connector and you can put it back in the cooler. The line was about $30 and the connector was $24.
Other line won't be in until Tues. I will get it wed and start the repair.
Got to say I like working on this truck. Don't need to lift it to work under it.
I appreciate everyones help.
Do you have parts #'s on that connector and the line? Thanks
This leads to another funny story. So online I read that you could not replace those, you had to replace the radiator. When I went to the dealership with the broken part to get a new radiator the parts guy said you can just get the fitting, so I bought that.
When I went to replace the second line this weekend, I bought the fitting first. When I went to the parts counter to order it another guy was at the desk. When I described the part he said they did not make them and I needed a new radiator.
Anyway, I ordered one for the other side assuming it was going to break and guess what? It came apart without an issue. So now I have an extra one. And they are $28.
