Sponsored by: Real Truck
Trans cooler lines
Old Feb 19, 2010 | 07:55 PM
GDog1911's Avatar
GDog1911
Trans cooler lines
How do you remove the lines that go into the bottom of the radiator? I have an 05 F-250 that has seen alot of salt and the line from the radiator to the aux cooler has rusted thru. I removed the plastic clip and the line will spin but will not come out. I tried the fuel line quick connect tool but it won't fit over the flare in the line.
Old Dec 17, 2010 | 09:50 AM
GDog1911's Avatar
GDog1911
Well, I patched the line that was leaking last winter and now another line is leaking. I found the correct tool finally after looking at eleven different auto parts stores. Problem is the tool is cheap plastic and won't work. These quick connect fittings are horrilble. I have talked to a mechanic friend and he says that most of the time he ends up replacing the radiator. Any ideas on how to get these "quick connects: apart? I guess QUICK is for the people on the assembly line so they don't have to actually turn a wrench, just stick the line the fitting. The salt in this area just eats everything. Already had the trans pan rust out and a couple brake lines. Thanks for your help.
BenardLenard
Feb 18, 2017 02:58 PM
brennanforgeron
15
Nov 14, 2016 10:31 PM
mattf76
Modular V10 (6.8l)
May 4, 2016 10:48 AM
mattf76
Apr 29, 2016 09:27 AM
UGA33
Jan 18, 2015 06:04 PM
