Electrical issues
Old Sep 30, 2013 | 07:38 PM
megawatt00's Avatar
megawatt00
Originally Posted by clintusaf
Can you expand on this? How would be HID's interfere with my tuner?
The ballasts make noise also known as EMI (electro magnetic interference) adding the ferrites to the cable helps to "absorb" or block the EMI from interfering with the electronics in your tuner. A kid at work has a ricer and when he added the HID's he had the same issue.. the place that installed them replaced every component on the system to no avail.. he mentioned it to me i had a couple of them left installed them on the cable and his problem disappeared
Old Sep 30, 2013 | 09:11 PM
clintusaf's Avatar
clintusaf
Ok. Well i guess its worth a shot. Are they expensive and where can i buy them?
Old Sep 30, 2013 | 09:31 PM
landmobile's Avatar
landmobile
They are not expensive. Try ferrishield.com, they have a large selection.
In my industry (mobile communications) we are frequently faced with mysterious problems in vehicle electronics that are caused by EMI, and ferrites are often the solution.
I recently serviced a truck with an electrically shifted PTO that would drop out every time the driver used his two-way radio. Turned out there was a protection circuit that was designed to disengage the PTO whenever it detected an unsafe condition, such as overspeed, high temp, etc. The RF from the radio was being coupled into the power leads of the protection circuit and causing it to "think" that there was a problem. A few ferrites took care of the problem.
Old Sep 30, 2013 | 10:06 PM
clintusaf's Avatar
clintusaf
I am actually pretty familiar with this realm as I am a ground radio troop in the Air force and have dealt with some spectrum management as well. Guess it just never crossed my mind that it could be the culprit here.
I took a a look at the site for the ferrite beads you mentioned and there are tons to choose from. Any suggestions on which ones to use that is a kinda of a one size fits all application?
Old Oct 1, 2013 | 09:49 AM
USMCJosh's Avatar
USMCJosh
HID's are spark plugs in a light bulb. The voltage required to light those things is in excess of 5K (5,000) volts. That much voltage can cause electromagnetic interference into other wires. For example your tuner or PCM. These guys want to see certain voltages/readings, etc from different components and with your HID's on it's possible there is voltage being induced into the wires giving false readings. It happens enough that manufacturers will usually put a shield around sensitive computer data line wires, or will install what is called a twisted pair of wires to help cancel out any electromagnetic interference.
The way it works is electrical flow creates magnetism. Magnetism induces current in a wire. If your tuner or PCM doesn't like the induced current it might cause your truck to run like butt because those components think they are getting info that is legit but is really false due to your HID's.
Old Oct 1, 2013 | 01:47 PM
landmobile's Avatar
landmobile
I think that they are pretty much designed in different sizes and shapes to work with various types of wire and cables, although there is some variation based on frequency response. The most popular type is the broadband ferrite, which is called Material 28. There are also low, high and microwave frequency formulations, but I would start with the generic broadband one.
The bisected core ferrites are the easiest to install, they just snap over the existing wiring without having to disconnect anything. Also, more is sometimes better. I have seen situations where one ferrite didn't do the trick, but two or three did.
Old Oct 1, 2013 | 02:20 PM
Smokiesman's Avatar
Smokiesman
Would these beads take the alt whine out of a car radio? Thanks
Smokie
Old Oct 2, 2013 | 05:05 PM
landmobile's Avatar
landmobile
Smokie
Probably not. Ferrites block interference in the radio frequency (RF) range, where frequencies are typically in the millions of cycles per second (MHz). Alternator whine varies as a function of engine speed and can have a number of causes, but occurs in the audio range (AF) with frequencies that are much lower, typically thousands of cycles per second (kHz).
I don't want to hijack the thread, but there are lots of causes and possible solutions to alternator whine. If you want to PM me or start a new thread we can get into more detail.
Old Oct 24, 2013 | 12:14 PM
clintusaf's Avatar
clintusaf
so after moving all my hid components to the passenger side battery and moving the ballasts as far forward as I could them, no more interference with my tuner. I did some research on forums on this subject and found that this is actually a very common problem for trucks that have a DP Tuner and HID's. I installed multiple ferrite beads at various locations on the hid harness and the DP tuner cable. I still have some EMI issues with my ABS though. When my headlights switch on, Sometimes my ABS light will illuminate, but thats all it does. Still working to solve this issue. I may end up just getting some type of cable shielding and just wrap the entire harness with it. Thanks for all the help on this guys.
WeBBy421
Jun 13, 2019 09:20 AM
psu927
Dec 30, 2012 11:22 AM
PsD007.3
Mar 3, 2009 10:10 AM
motomom48
Electrical Systems/Wiring
Feb 8, 2008 01:27 PM
WhipsnHorses
Aug 1, 2003 09:19 AM
