Sponsored by: Real Truck
Body Security Module
Old Jun 9, 2019 | 08:23 PM
WeBBy421's Avatar
WeBBy421
2005 F250
I have been searching for the short in my truck for months. If it sits for a couple days, the batteries sometimes go dead.
Generally, there is a power draw from the Body Security Module (BSM) for about 1-1/2 minutes. FINALLY figured out that sometmes the power draw is continuous, e.g., the pwer draw does not shut off after 1-1/2 minutes.
My guess is that there is a relay somewhere and that the relay is failing.
WHERE IS THE BSM RELAY located?
Thanx
Old Jun 10, 2019 | 09:02 AM
alloro's Avatar
alloro
There isn't one, the BSM is fed directly from it's fuses and not through a relay. FYI, the BSM is located under the dash on the passenger's side.
Old Jun 10, 2019 | 11:35 AM
Fefanatic's Avatar
Fefanatic
Not sure about '05 but on a '08 there is a smart module behind the passenger kick panel. It quite a few harnesses plugged into it. I know it controls the interior lights, door light switches, and shifter interlock. I had one go bad on a '08 and the interior lights stayed on, the door ajar warning displayed for all four doors, and I could not get it out of park with the ignition switch on. Replaced module and all went back to normal. Don't know if this helps you are not but check it anyway.
Old Jun 10, 2019 | 08:20 PM
WeBBy421's Avatar
WeBBy421
Yeah, I need to figure out where it is as I am sure it is what is causing my dead battery.
Maybe I can find a video of exactly where the module is located.
While I can live without all security stuff for some reason removing the BSM fuse takes out my 4 wheel drive (WTF). I do not see anything wrong with the BSM fuse in except that it usually continuously draws power and does not shut off when it supposed to.
If anyone have a picture or video where it is located, that would be a big help.
Thanx
Old Jun 10, 2019 | 08:23 PM
Fefanatic's Avatar
Fefanatic
If it's the same as my '08 you can't miss it. Remove the passenger front kick panel and you will see it. It is the box that has fuses and a ton of wiring connectors plugged into it. It takes two screws to remove. I believe they are 7mm. Once those two screws are removed it will slide out of it's slot in the body. You will have fun twisting and squirming to get those connectors off.
Old Jun 11, 2019 | 08:27 AM
WeBBy421's Avatar
WeBBy421
Lots of different locations I guess as some say behind radio, some say under dash, and you say on passenger side. Gonna have to see where it may be in a few days - after cutting and baling hay.
Why in the world would the 4x4 be tied into the BSM fuse.
Old Jun 13, 2019 | 09:13 AM
speedfreak78's Avatar
speedfreak78
Everything is tied to everything in newer vehicles. Disabling 4wd could just be one part of the security system default when it loses power.
Old Jun 13, 2019 | 09:20 AM
Fefanatic's Avatar
Fefanatic
It is what it is. In my case the smart module wouldn't allow the truck to come out of park. I never checked the 4X4 so I can't say about that.
Napewastewin
Jan 28, 2023 11:44 AM
1duallyman
Dec 21, 2011 08:53 PM
motomom48
Electrical Systems/Wiring
Feb 8, 2008 01:27 PM
bsw9323
Apr 23, 2004 05:56 PM
WhipsnHorses
Aug 1, 2003 09:19 AM
