Mud flaps/Winter protection?
I was just wondering if anybody on here is running any mud flaps. My thought is that if I can get any wide enough, it will keep my tires from kicking stuff up onto the body of the truck. I'm going to be driving it all winter, and I live in Illinois where they salt the roads mercilessly. Any other suggestions as to what I should do to minimize rust? I've basically gotten rid of all the rust on the truck (frame cleaned and painted, new cab corner, new passenger's door, new rear wheel arches etc.) and I'd like to keep it that way.
Thanks
https://www.ford-trucks.com/forums/1...mud-flaps.html
https://www.ford-trucks.com/forums/9...dentsides.html
Set up an undercarriage wash system... it can be as easy as a couple of those oscillating lawn sprinklers... the slow moving kind that swings an arc side to side. Park the rig over 'em, turn it on for a minute or so.
Scrub clean and paint the wheel wells and the back, unseen side of the front and rear bumper. I prefer gloss black because it's easier to spray off dirt and mud from a slick surface than a rough surface.
In fact, paint all bare metal because paint is not only an aesthetic consideration but an anti-corrosion coating as well.
Periodically and liberally spray WD-40 in the chassis' nooks and crannies (after cleaning them of course). It's a light oil and can be washed away in the spring.
Clean out the cowl and the vent bowls and keep them free of leaves & debris.
Use antiseize on nuts and bolts. Torque to spec if required.
Use dialectric grease on all light bulb bases, light sockets, and exterior electrical connectors.
Before every winter, do a full chassis lube... hit up every zerk fitting.
Lube all door hinges, locks, tailgate pivots, hood hinges, hood latch, tailgate latch.
Clean out the door drain holes. In fact, paint the inside bottoms of the door... again, with a gloss paint.
As much as it would be best to not drive it, I just can't. I love the truck and got it to drive it as a daily, since it gets 20 mpg now with the diesel. I'm just looking to minimize the rust caused by all the wonderful things they "treat" the roads (and our vehicles) to up here.
