Anyone else run mud flaps?
Old Sep 2, 2012 | 12:39 PM
montana_highboy's Avatar
montana_highboy
Post em up if you do...
Old Sep 2, 2012 | 01:13 PM
burnout400m's Avatar
burnout400m
Hey, I'm originally from Pendleton. Used to drive by Woodpecker all the time.
I don't have a dent-side but I have some dinky flaps a PO put on my brick nose. I'd like to get some bigger ones cuz I think they look cool.
Old Sep 2, 2012 | 01:53 PM
arctic y block's Avatar
arctic y block
I like flaps and they are a good thing up here as most roads are gravel. But when hunting and wheeling they get torn off the first time ya cross a ditch and don't make it and have to back out. So a hanger with a quick disconnect like a receiver hitch has should work so they can easily be removed when wheeling. I doubt there is anything on the market like what I am saying so I guess I need to build a hanger. Than I too can have flaps.
Old Sep 2, 2012 | 01:57 PM
burnout400m
Or trim them just short enough to not reach the back tires.
Old Sep 2, 2012 | 05:46 PM
NBC-Steve's Avatar
NBC-Steve
I just got a fix it ticket from a very youg and enthusiastic California highway patrolman for no mud flaps. Kid didn't know that my truck didn't come with them but I wasn't going to argue. Now I have to find something and clamp it on for one of my buddies to sign off the cite.
Old Sep 2, 2012 | 07:42 PM
spikinfool05's Avatar
spikinfool05
heres what i have
Old Sep 2, 2012 | 09:05 PM
littlecobra1977's Avatar
littlecobra1977
I know of a guy that welded round stock to his frame, with a small hole drilled in the end for an R key to fit in, the flaps slide on and off with ease and the bar is up out of the way. He uses his truck for bogs and drives it home if nothing breaks.
Old Sep 2, 2012 | 09:58 PM
spikinfool05
also can do like the rock haulers just v notch the holes backwards when they tear off just bolt them back on
Old Sep 2, 2012 | 10:28 PM
hasteranger's Avatar
hasteranger
my truck had flaps mounted to underbody tool boxes in front of the tires, and flaps behind the tires. Was a little bit much, imo, and they were really stiff rubber with big metal weights on the ends, which made it difficult to stick your head under to check out the rear end and stuff. I took em off. The brackets are still welded to the bed for the rear ones, but they aren't required here in WV and I can't find any decent looking 12" wide flaps to fit them, and they wouldn't really be good for a play truck anyway.
the flaps on there before had thin chain going to the weights so they couldn't reach the tires.
Old Sep 2, 2012 | 10:32 PM
thegetupkid7609's Avatar
thegetupkid7609
Build it and they will buy it!
Old Sep 2, 2012 | 10:53 PM
jeff14346's Avatar
jeff14346
Had them on the back of my truck, took them off rubbing the ground did not like them, G-PA installed them when he had the truck
NBC-Steve, you realy got a ticket?? WTF, now I am wondering if I should put something back on
Old Sep 2, 2012 | 11:38 PM
FordMaverickFan's Avatar
FordMaverickFan
I just bought some plastic ones with Ford written on them for winter, I gotta find a way to mount them without drilling into the wheelwells...
Old Sep 2, 2012 | 11:40 PM
NBC-Steve's Avatar
NBC-Steve
"WTF" was exactly what I said when he pulled me over, he probably didn't like me challenging him but when he approached me and we made initial contact then he told me the reason he pulled me over. "Mud Flaps!" I took my sunglasses and moved then down from my face and I looked over the top and said "Mud Flaps? Really? That's a rather pathetic equipment violation wouldn't you say?" I'm 50 and he was around his mid 20's so he was young and wanted to do his job. My other job is Public Safety Communications Engineering so I talk the "Talk" being around cops and firefighters all day. I told my story to other cops I know and they all just rolled their eyes and said some really nice choice words about the CHP.
Here's the back end of my truck. Around here this is very typical of almost all four wheel drives trucks.
I wouldn't waste you time putting them back on unless you want to or your state requires them. California Vehicle Code is rather vague on the specifics of the mud flaps and CHP has their own policy on how to enforce this law and its just as vague as the CVC. I plan on temproarally bolting something on and have one of my buddies sign it off then I'll remove them and forget it ever happened.
Old Sep 3, 2012 | 12:13 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
I'd like to get a set that say "CAUTION: WIDE TURNS" They'd fit the truck perfectly, just like the song says "give me forty acres and I'll turn this rig around!"
Here's what I've got on there now:
The only problem I have with them is they drag on the ground with the truck loaded up.
Sam
Old Sep 3, 2012 | 10:22 PM
montana_highboy
That's basically the same reason i run flaps, courtesy for the guy behind me, lots of gravel roads here and cracked windshields are no fun.
