Charging system issues
Old Sep 24, 2013 | 05:38 AM
skingrey's Avatar
skingrey
2005 Explorer XLT 4WD 4.0 6 cyl. While driving home, battery light flickered accompanied with audible tone with check charging system message. Battery voltage indicator does indicate a drop in voltage. The alarm is more rapid when below 900 rpm and at idle. I check battery with multimeter, while running at idle, I got a slow drop in voltage. No drop when engine is off. Battery connections are good, new spark plugs installed 2 months ago. I'm thinking alternator went bad on me but would like a second or several opinions. All suggestion are apprecited and welcomed. Thanks in advance.
Old Sep 24, 2013 | 06:20 PM
Graygeorge's Avatar
Graygeorge
You should be getting a 13+ volts when idling.
Old Sep 24, 2013 | 08:20 PM
steve(ill)'s Avatar
steve(ill)
WOuld help to know the voltage, but by your description it sounds like alternator failure. "Average" life is about 150K miles, some longer, some shorter. Check all cables for corrosion, tight clamps... then look at new alternator.
ed77
Modular V8 (4.6L, 5.4L)
20
Sep 3, 2020 11:15 AM
deerhuntertyler
19
Jan 11, 2013 09:53 PM
robs_seven
Dec 4, 2012 03:43 PM
cyborghunter
Mar 5, 2012 06:47 PM
CATFORD
19
Sep 27, 2007 10:06 PM
