Charging system
Old Mar 23, 2019 | 08:08 PM
ed77's Avatar
ed77
Charging system
Hi guys, I am Ed. I have a 2003 Expedition. I love it. My problem is either battery or alternator. I check the voltage with the engine off and I get around 11.5 volts on the terminals. I start the engine and the voltage is still 11.5 volts. I get a battery light. At 2k RPM, the light goes off. After it idles for a couple of minutes, the battery light comes back on. I am in the soup either way. But can anyone suggest a way for a novice to tell the problem? Thanks
ed77
Old Mar 24, 2019 | 06:01 AM
JWA's Avatar
JWA
Your problem could be both failing components but almost 100% your alternator is on its way out, quickly at that. Every symptom you post points to it.
The fact you get nothing more than battery voltage at the terminals with engine running shows the alternator has no output. Since you don't idle at 2K RPM that's not a reliable test, that the battery warning light comes on after a while just points more and more towards the alternator.
You'll want to address this ASAP before you ruin the battery too. If you replace the alternator make sure every every connection and terminal is completely free of corrosion. I usually replace the serpentine belt too especially if hasn't been changed recently.
Old Mar 24, 2019 | 09:56 AM
ed77's Avatar
ed77
Charging system
Thank you for your help. because the battery is only 14 months old, I have decided to begin with another alternator.
Old Mar 24, 2019 | 10:55 AM
alloro's Avatar
alloro
Does the voltage jump up to around 14v when the light is out?
Old Mar 24, 2019 | 11:24 AM
lv2race's Avatar
lv2race
If you have an auto parts close by, they may be able to test your alternator in the vehicle. Depends who you go to, but call around as it won't cost you anything
Old Mar 24, 2019 | 07:22 PM
ed77's Avatar
ed77
I visited one of the major stores and had two tests. One on vehicle conclusion was definitely the alternator. Later in the day, I had the battery tested in the same shop for an hour. Conclusion, battery bad. That baffled me. So after 165,000 miles, I have decided to probably replace both. Thank you guys for your help and suggestions.
Old Mar 25, 2019 | 09:52 AM
alloro's Avatar
alloro
Just an FYI. On my 01 Navigator the battery light would be on at idle then go out as the RPMs increased. I bought a new set of brushes and took the alternator apart. I replaced the brushes and cleaned the armature contacts. After putting it all back together the alternator worked perfect and has to this day. The repair cost me about $15 for the brushes when a new alternator was up around $300.
Old Mar 25, 2019 | 11:40 AM
ed77's Avatar
ed77
Sounds like you had the same problem as I do. I, however, must opt for another alternator. I would not know a brush from a boomerang.Found a used one for $70. Not ideal, but gotta tie some ends up. Few months, and I will replace it. Thanks for your help and suggestion(s).
Old Mar 28, 2019 | 01:03 PM
ed77's Avatar
ed77
Guys, I got a new alternator and battery for a 2003 Expedition. Runs but still got a battery light. is there a regulator or is there another situation to consider? Thank you
ed77
Old Mar 28, 2019 | 05:17 PM
jimbomitch's Avatar
jimbomitch
Check wiring and grounds. It's also possible the new alternator isn't functioning. Been through the latter with 2 consecutive bad ones.
Old Mar 28, 2019 | 06:08 PM
ed77's Avatar
ed77
Thank you. I checked the voltage on the battery engine off and got 12.2 V Engine running, I get 11.5 V and a voltage light. I drove, fearfully, about 10 miles and checked again. The voltages had not changed. New battery. Replaced alternator. I am puzzled.
Old Mar 28, 2019 | 06:18 PM
jimbomitch's Avatar
jimbomitch
If you have a new battery the voltage should be around 12.6 or better. Your problem is going to be wiring (that includes cleaning the battery terminals). Again, just because a part is new, doesn't necessarily make it good.
Old Mar 28, 2019 | 06:58 PM
ed77's Avatar
ed77
The battery connectors are pretty crappy. But it ain't like it was back in the day. Red to positive black to black. There are at least three connectors at the positive post. But you are right. Gotta clean up those connectors. Will post what happens. Thanks
Old Mar 29, 2019 | 09:43 AM
alloro's Avatar
alloro
Is the belt tight? If not there could be an issue with the tensioner or the belt is stretched to it's maximum.
Old Mar 29, 2019 | 07:22 PM
Tedster9's Avatar
Tedster9
Good tight clean connection battery cables are just as important as the battery itself. They are approaching 20 years old; if you live in a salt-belt state... At least break them open at each terminal end, wire brush the block and frame/body connections to bright shiny metal and tighten securely. Once a year wouldn't be too often.
