alt ?
Old Mar 5, 2012 | 04:42 PM
cyborghunter's Avatar
cyborghunter
alt ?
how would one go about testing if my alternator is working correctly? i keep having a dead battery after it sits for a few hours while at work or overnight. this started friday morning the battery is less than 6 months old so its gotta be a charging issiue right?
Old Mar 5, 2012 | 05:10 PM
rla2005's Avatar
rla2005
Not necessarily.
Take the alternator out and have it tested.
Another quick method is to charge up the battery, then measure the voltage without the truck running. Start the truck, then measure the voltage across the battery again. If the alternator is charging the voltage with the engine running should be higher than with the truck not running. This is just a basic test, the alternator really needs to be tested.
Old Mar 5, 2012 | 06:28 PM
cyborghunter
i did that about 12-13 v off and 14.4v while at idle. but i cleaned all the gunk outta the conections well see if that helps.
Old Mar 5, 2012 | 06:47 PM
rla2005's Avatar
rla2005
Those numbers sound reasonable. Corroded connectors and/or bad cables will severely tax the battery, charging and starting system.
NotEnoughTrucks2014
Apr 4, 2017 06:48 PM
annaleigh
16
Jan 1, 2017 04:01 PM
browntown3
Aug 8, 2008 08:31 PM
bsmith8
Electrical Systems/Wiring
Jan 5, 2004 05:27 PM
bcsbadboys
Oct 16, 2002 08:04 AM
