I have been just using the truck close by but now venturing further out I'm in the middle of fixing the charging system. So far I have replaced the alternator with a 65amp alt, new external regulator, belts, and battery. I still don't think I'm charging. I cleaned all connectors when installing the new goods.
I'm new to the external reg stuff so not sure what I'm hunting down. I've got a crappy repair manual from the parts store but its very vague.
First crank with new stuff was great, drove it about 10-15 miles with a few cranks. When at idle I'm reading 12.5 volts at the battery, I'm used to 13-14ish. Then while running I unhooked the battery and she died, I thought if it were charging it would idle unhooked.
Any ideas, advice, schematics would be appreciated.
I know a lot of you have went to the high output upgrade but I'm just not to that point yet. Trying to just get it running and consistent.
12.5 volts would be reasonable at idle, in gear, with the brakes applied. Under what conditions was your measurement taken? Is this the single item that makes you suspect a charging system problem, or are there other symptoms? You may not even have a problem.
Never do this! The battery is responsible for sinking alternator output current and helps provide regulation. If you unhook the battery, the system voltage can spike very high and fry any onboard electronics, such as the ignition module. The fact that the truck died when you did this tells you nothing about the charging system.
Under those conditions, I would expect a little higher. If you rev the engine, does the voltage climb to 14? This will at least tell you if the regulator is responding. If it is, then there are a couple things to check with regard to the low reading at idle.
