Hard starting and rough running stroker
Old Sep 25, 2013 | 06:13 AM
427 fordman's Avatar
427 fordman
You can ohm the injectors and glow plugs from the harnesses. That will get you started anyway. Injectors should be at our close to 3.2 each, glow plugs 1ohm each. Glow plugs are outer two pins on each wiring plug, injectors are the ones beside them. The center is a common ground.
Old Sep 25, 2013 | 04:24 PM
Mike Hannahs's Avatar
Mike Hannahs
With this test does the key need to be on or anything,im a noob with some of the testing stuff but the only way to learn is to do it and i will hahah
Old Sep 26, 2013 | 11:44 AM
DarkStarMedia's Avatar
DarkStarMedia
what part of the desert are you in? If you are near by I'd be happy to help.
And you do the ohm (resistance) testing with the key off.
Richard
Old Sep 26, 2013 | 01:43 PM
Mike Hannahs
Richard
Im in southeast Utah,thanks on the testing with key off
Old Sep 26, 2013 | 02:11 PM
DarkStarMedia
Oh... that's not real desert....
Richard
Old Sep 27, 2013 | 03:05 PM
Mike Hannahs
Richard
Yeah i bet you live in Az or something huh where its true desert hahaha
Old Sep 27, 2013 | 03:23 PM
madpogue's Avatar
madpogue
All this talk about dessert is making me hungr..... oh... wait... never mind....
Old Sep 27, 2013 | 05:34 PM
Mike Hannahs
Hahaha yeah im hungry to haha got pizza on the way haha thats my desert,oops i meant dessert hahaha
Old Oct 4, 2013 | 03:03 PM
Mike Hannahs
Just a update on the hard starting stroker, my hpop pressure was low, i filled it up and started it and it started bad the first time but as it was idling it kind of reved up and went back to idle and smoothed out very nicely, then i shut it down and let it sit for a bit and cranked it up again and it fired up like it should, one thing i am wondering though is when you fill up the hpop if you over flow it does it need to be pumped out? i was once told that the over flowed oil will run back into the oil pan and it would be fine, is that correct? and one more thing, im going to change the oil in the hpop with a oil change and im wondering how much oil does the hpop hold?
Old Oct 4, 2013 | 04:31 PM
427 fordman
You don't need to change the hpop oil. You're still not getting all the old oil out that way. It circulates all the time so no real need to.
You can't really overfill the hpop. Once the resevoir is full, its just gonna run out and make a mess. It holds around a quart, give or take a little.
Old Oct 4, 2013 | 11:56 PM
Mike Hannahs
Oh ok hahah, im hoping its not leaking somewhere, it was only a 1/4 qt low was all but it made all the difference on the way it runs, if it was leaking somewhere wouldn't it run empty or would it find a spot and stay there? and if there is a chance it is leaking where is the most common places they leak at?
Old Oct 5, 2013 | 06:24 PM
Mike Hannahs
After running that truck a bit yesterday i had checked the hpop oil again today and it was a 1/4 qt low again, there isn't any way that it can mix into the radiator fluid is there? or is it something that comes from the oil cooler? that truck has some issues with leaks im trying to seal up hahah, i know the oil cooler is leaking for sure.
Old Oct 6, 2013 | 11:16 PM
  #28
madpogue's Avatar
madpogue
Oil cooler can allow coolant to leak into oil or vice-versa. But remember, there is no "HPOP oil" per se. What you see in the reservoir is part of the lube oil, and gets circulated every time you run the engine.
Old Oct 9, 2013 | 08:13 PM
  #29
Mike Hannahs
Is there a place that maybe it could leak out some? i know on my 7.3 mine is to the top at the bolt i pulled to view it, i filled it up 6 months ago and its been there ever since and i was told it would go back down but it hasn't but on my wifes 7.3 it goes back down there for some reason and when it is as low as it gets it runs bad, it wont hardly drive without almost dieing if its not warmed up to opp temp and it idles very rough, rough enough that it gets the engine rocking back in forth but when i top that off it fires rite up without any trouble at all, i do know its got some leaks needing fixed i just need to find the place it all comes from, the oil cooler is one of those places for sure, its time to park that truck and hunt them all down and seal it up to see if that keeps it full, is there any common places that the hpop would leak if at all?
Old Oct 9, 2013 | 08:16 PM
  #30
Mike Hannahs
One more thing to is if the oil cooler is leaking oil into the coolant would there be any coolant in my oil pan because when i check it its clean as a whistle no foam or nothing like that
DJHoff
Oct 2, 2016 06:46 PM
kent hittle
16
Feb 11, 2016 04:18 PM
Dev
Jan 10, 2010 07:11 PM
RushN350
Jan 14, 2006 07:10 AM
IKE
13
Apr 21, 2005 01:26 PM
