hard starting
Old Apr 11, 2005 | 11:07 AM
IKE's Avatar
IKE
hard starting
I have a 96 F-350. A few days ago it was hard to start so I changed the fuel filter and filled the tanks. It was hard to start yesterday morning. This morning it would not start after several tries. The temperature was about 38 degrees. I waited for the glow plugs as usual, tried to start it, but it wouldn't fire and huge amount of gray smoke from exhaust and some from under the hood. I let it set a few minutes and tried it again, same thing. Did this several times,same thing. Would some one please tell me what you think my problem is? I would really appreciate any help. I live 34 miles from town, so do a lot of my own maintence and repairs.
Old Apr 11, 2005 | 01:29 PM
MentalState's Avatar
MentalState
Bad glow plugs?
Old Apr 11, 2005 | 01:55 PM
Max1775's Avatar
Max1775
Did you check your glow plugs and glow plug relay? Possibly even a weak set of batteries...
Max
Old Apr 11, 2005 | 02:25 PM
IKE's Avatar
IKE
Thanks for your come-backs. Is new glow plugs a difficult job? Any tips about that would sure be appreciated. Thanks. IKE
Old Apr 11, 2005 | 03:16 PM
Max1775's Avatar
Max1775
GPs are a pain in the rear! Check out the relay first, lot easier to fix. Just search the forum for it, you'll get a ton of info.
Max
Old Apr 11, 2005 | 03:37 PM
touchofgrey's Avatar
touchofgrey
IKE
Before you dive into the glow plug side of things.....make one quick check. As your turning the engine over; look down at the tach. Is it moving at all? If it isn't, I'd say that you probably have a CPS that's gone out.
Old Apr 11, 2005 | 06:58 PM
edub32's Avatar
edub32
Also, check your batteries with a tester...weak batteries can also make the engine hard to start
Old Apr 12, 2005 | 03:49 AM
Crumm's Avatar
Crumm
Click Here for a great article on testing and replacing both the glow plugs and glow plug relay.
Old Apr 19, 2005 | 04:12 PM
IKE's Avatar
IKE
I want to say thanks to all the guys for their input about replacing glow plugs.
IKE
Old Apr 19, 2005 | 04:20 PM
'96 F-250's Avatar
'96 F-250
I had bad batteries after I bought my '96 PSD, but if it was enough power in them to turn the engine, it started. Period! So if you have a bad battery you won't be able to crank the engine for a long time. I'd check the GP-thingy....
Old Apr 19, 2005 | 04:41 PM
Max1775's Avatar
Max1775
Not trying to argue, just sharing from personal experience. Weak batteries can make the truck very hard to start. The engine may turn over, but not fast enough to fire. It has happened to me, and several of our work trucks.
Max
Old Apr 19, 2005 | 04:59 PM
'96 F-250's Avatar
'96 F-250
Yes, I agree there, but in this case IKE said: "This morning it would not start after several tries".... That you cannot do with bad batteries..
Old Apr 19, 2005 | 06:37 PM
touchofgrey
IKE
So.....you changed the glow plugs out....and now everything fine?
Old Apr 21, 2005 | 01:26 PM
IKE's Avatar
IKE
I found a loose battery terminal. Seems to be O.K. now. Also, weather is a lot warmer last few days. Thank you guys for all your input. I'm sure I'll be back with more questions. Thanks again,
IKE
