Tachometer Problem
Old Sep 23, 2013 | 08:40 AM
boonslick's Avatar
boonslick
Tachometer Problem
87 F150 5.0L 4EOD
My tachometer is erratic. It works fine for 2-3 months and then it will malfunction for a couple of weeks with the needle moving erractically; it may read 3000 rpm at idle or sometimes move while driving at a steady speed.
What is causing this?
Thanks
Boonslick
Old Sep 23, 2013 | 09:46 AM
subford's Avatar
subford
Either bad wiring, resister or bad tachometer.
Never heard of a 4EOD, did you want to say AOD?
An the E4OD did not come out until 1989 as far as I know.
Old Sep 23, 2013 | 10:08 AM
timbersteel's Avatar
timbersteel
+1 with Subford
Sounds like the truck runs fine other than the tachometer problem. Wiring sounds like the culprit. Check the wiring at the coil and ensure it isn't corroded or loose. I would remove the coil pigtail and clean the contacts and put some dielectric grease on them. Will help to keep corrosion/moisture from causing electrical problem there at the connection.
Old Sep 23, 2013 | 02:59 PM
boonslick's Avatar
boonslick
Tachometer
Where is the resistor?
The truck has 4 forward gears is all that I know.
First, I will check the coil as advised and see if that works. I do not think the tach is defective or it would not work correctly as it mostly does. Just a thought.
Boonslick
Old Sep 25, 2013 | 08:15 AM
boonslick's Avatar
boonslick
Tachometer Problem
Originally Posted by timbersteel
+1 with Subford
You are correct in that the truck runs very well. I cleaned all connections with Brake Cleaner, waited and then plugged the connectors. I also applied Silicone Dielectric Grease to the Coil terminal.
If I understand correctly, subford is referring to the attached resistor which is fine as the Radio is trouble-free.
I have a spare coil which I will install today and perhaps this will fix the issue.
Thanks for your help!
Mark
Old Sep 25, 2013 | 08:24 AM
subford's Avatar
subford
No that is the Radio capacitor an not a resistor.
The resistor is inside the wiring harness someplace.
MustangGT221
Nov 26, 2008 10:34 AM
Bronco_sport
1966 - 1977 Early Broncos
Jan 20, 2004 10:10 AM
Skagit
Electrical Systems/Wiring
Nov 29, 2003 09:45 AM
TheWiz427
Aug 17, 2003 08:28 AM
josh3972
Bronco II
Oct 13, 2001 11:02 AM
